MrOizo wrote:Money!
cat007 wrote:MrOizo wrote:Money!
Bollocks - if you've got the engine then you just need some time, and a front cross-member IIRC.
Doesn't take much $ - if you're smart about it.
iamawesome wrote:Mine is a widebody with a good body that's already had a manual conversion an adjustables etc done so hence the reason for the change rather than selling. Ahh I'll check the mounts it's an 89 an has the facelift lights so hopefully it is. I was planning on going for the vvt and keep it fairly stock for reliable power, is it any different for a 2j? Or are they more work?
Looonie wrote:The main hassles with the VVTI/2JZ conversion is the wiring, less diagrams/info for it. And some clearance problems on the 2JZ.
