1998 GTT Caldina issue
Postby Nzpure » Mon Mar 12, 2012 5:51 pm
Ok so my VSC light comes on and stays on intermettenly,
Took it to toyota to get the codes checked.
No codes everything seems fine he seemed to think it was the tyres over inflated so he dropped the pressure to about 30 psi i believe.
Still comeing and going.
Any idea's?
Nzpure
Postby cat007 » Tue Mar 13, 2012 9:53 am
What's VSC?
Postby 1I1 » Tue Mar 13, 2012 9:54 am
Vehicle stability control.
Use of a different sized tyre (ie space saver) throws codes
TRD Clicky >>Here
1I1
Postby cat007 » Tue Mar 13, 2012 9:56 am
Crazy. Guessing not all Caldina's have this. Pretty sure our '98 GTT doesn't!
Postby B_giB » Tue Mar 13, 2012 9:58 am
cat007 wrote:Crazy. Guessing not all Caldina's have this. Pretty sure our '98 GTT doesn't!
Only the Tiptronic GTT's have it
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby Nzpure » Tue Mar 13, 2012 10:42 am
I haven't used any different sized tyres or anything like that..
Nzpure
Postby BZG Wagon » Tue Mar 13, 2012 10:58 am
I think there was a thread on it ages ago: could be a speed sensor on one of the wheels, steering rack sensor, it's wired itno your brakes etc.
Are you sure Toyota actually checked for codes? I say this because I took my car to Albany Toyota twice with a fault, both times they told me they hooked it up to the scanner and it was a total load of shit. When I checked myself it threw two codes relating to the two faults I told them about. :roll:
BZG Wagon
Postby BZG Wagon » Tue Mar 13, 2012 11:02 am
^^ Just to be sure you can check for codes yourself:
To run diagnostics just locate the OBDII connector close to the drivers door and by the little compartment where your right knee is when sitting in the drivers seat.
Bridge TC & CG and turn on the ignition. Count the engine flashes then google them to see if there are any issues.
BZG Wagon
Postby fivebob » Tue Mar 13, 2012 8:47 pm
BZG Wagon wrote:^^ Just to be sure you can check for codes yourself:
I think that just checks ABS codes, to check TRC/VSC codes you need to bridge TS(Pin 14) and CG(Pin 4)
Postby BZG Wagon » Wed Mar 14, 2012 12:11 pm
Good to know. Thanks.
BZG Wagon
