fangsport wrote:have you washed it or got it wet in a downpour recently?
FST4RD wrote:fangsport wrote:have you washed it or got it wet in a downpour recently?
It stays outside all the time, and it has been raining quite heavily recently. Why's that?
jaypines wrote:have a look at the dash dimmer switch if you have it... might not be connected or broken.
Alex B wrote:Tail lights are on the same fuse as dash lights for some toyotas. Most frequent cause of this is someone using the illumination wire as an earth when putting a new stereo in.
yip, guilty of that one.Alex B wrote:Tail lights are on the same fuse as dash lights for some toyotas. Most frequent cause of this is someone using the illumination wire as an earth when putting a new stereo in.
cat007 wrote:Sounds like a perminant fix.....
