edwagon wrote:you gotta pay the cost to be the boss!
solitaire wrote:It started doing this when i changed the cap, plugs and rotor.
No I did not, didn't quite fit the budget at the time - you think this could be a contributor?Mr.Phreak wrote:solitaire wrote:It started doing this when i changed the cap, plugs and rotor.
Did you do the leads at the same time??
Is that the same as bridging the two terminals in the diagnostic plug? if so its not showing any codes on the check engine light - not that I put a great deal of faith in the on board diagnostics on the ecu - they have never helped me with any gremlins on the mr2gmacrae wrote:I'd get the car scanned for codes, i bet the ecu is complaining about the cam angle sensors (dizzys) being out or something
solitaire wrote:No I did not, didn't quite fit the budget at the time - you think this could be a contributor?Mr.Phreak wrote:solitaire wrote:It started doing this when i changed the cap, plugs and rotor.
You raise a very good point, they did look a bit tatty - I would have thought leads would either work or not work? Or can they produce intermittent faults too?
edwagon wrote:solitaire wrote:Leads can make a huge difference
They affect the strength of the spark greatly
They can partially break down - and you'd be hard pressed to pick up a small/intermittent weak spark misfire on a smooth/quiet v8
But it could def cost you a litre or two/100km
yeah ucf 11 - ok so maybe I need to get an OBD1 tool anyway, cheers.gmacrae wrote:yours is a ucf11 right? not sure if the OBD1 computer will tell you more with a scan tool than the dash light would. It's the first place I'd start anyway. Leads are another good possibility though. They'll be pretty brittle after 18 years so changing the caps etc could've stuffed them
Users browsing this forum: Majestic-12 [Bot] and 13 guests
