High temp exhaust paint. where to buy etc
Postby XSVWGN » Sun Apr 01, 2012 7:35 pm
Hey well i did a search and it came up with nothing but rubbish. My wagon sat outside at my brothers in Newlands Wellington for a while and the weathe is crap and has corroded the manifold etc and i want to make it look nice.
Where do i get high temp exhaust paint? Repco/Supercheap or a specialist? I want to get the manifold sand blasted then painted
Matt
2008 Kia rio - work car
XSVWGN
Postby Dell'Orto » Sun Apr 01, 2012 7:43 pm
VHT make a good high temp paint, I used it on my old MR2 to good effect. Rated to 1000 degrees centigrade
Postby iOnic » Sun Apr 01, 2012 7:46 pm
Used the VHT stuff (pretty sure it came from Repco) on the Euro-R's header - still looked perfect the day it was sold. Highly recommended!
Postby XSVWGN » Sun Apr 01, 2012 7:50 pm
Sweet as. I will be pulling it all apart soon. Getting work done on the turbo aswell as polishing Alloy to make things looking better
Matt
XSVWGN
Postby ch4ng » Sun Apr 01, 2012 8:11 pm
Yep VHT exhaust paint is great, you can also get it from BNT (wheel paint was $6.5 a can so the exhaust paint won't be too much more)
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby Bling » Sun Apr 01, 2012 8:18 pm
Depending on colour you can get matt black, possibly others, in the wood burner section of DIY type stores, Mitre10 etc.
Postby XSVWGN » Sun Apr 01, 2012 8:20 pm
ch4ng wrote:Yep VHT exhaust paint is great, you can also get it from BNT (wheel paint was $6.5 a can so the exhaust paint won't be too much more)
Heading there tomorrow anyway so i will ask them. Thanks for the advice!
Matt
XSVWGN
Postby evil_si » Sun Apr 01, 2012 8:43 pm
Best stuff ive used is caterpillar muffler black
Only available from goughs
evil_si
Postby Bazda » Mon Apr 02, 2012 12:55 pm
Get it Pro Coated, will last MUCH longer.
Postby XSVWGN » Mon Apr 02, 2012 10:02 pm
Bazda wrote:Get it Pro Coated, will last MUCH longer.
Where would i get this done then?
Matt
XSVWGN
Postby evil_si » Sat Apr 14, 2012 5:32 pm
At procoat, but they are in auckland
evil_si
Postby Heylin » Mon Apr 23, 2012 5:37 pm
+1 on VHT, currently using on my Subtech downpipe, and my old MR2 had it on its turbo exhaust housing and screamer pipes (= very hot) still looked good after a year of running.
Its all in the prep work and correct curing process.
Heylin
Heylin
Postby XSVWGN » Mon Apr 23, 2012 7:11 pm
Heylin wrote:+1 on VHT, currently using on my Subtech downpipe, and my old MR2 had it on its turbo exhaust housing and screamer pipes (= very hot) still looked good after a year of running.
I purchased the VHT 1300-2000 degree farenhite paint. True-no-turbo is sand blasting my manifold and then heating it up with a gas torch then applyng the paint as thats the best way apparently
Matt
XSVWGN
Postby evil_si » Mon Apr 23, 2012 8:04 pm
XSVWGN wrote:I purchased the VHT 1300-2000 degree farenhite paint. True-no-turbo is sand blasting my manifold and then heating it up with a gas torch then applyng the paint as thats the best way apparently
Matt
Yup thats correct, spray it whilst its hot,
the kitchen oven also works well, 8)
evil_si
Postby Mr Ree » Mon Apr 23, 2012 8:18 pm
I had my turbine housing, exhaust manifold, down pipe and dump pipe coated at procoat and have to say I wasnt very happy with the job.
Upon removing it from the box, the coating was noticeably inconsistent, some areas had less than half the amount that other areas had, and it was nowhere near as durable as I would have expected given the cost. Even the slightest of knocks or bumps removed the coating and it didnt take many heat cycles for it to thin even more in places.
At a guess, whatever their process is, I presume that part of the prep stage was omitted, or done a bit too casually, as I have seen their work on cars in magazines and the difference is night and day.
wak thud gush!
Mr Ree
Postby Bazda » Wed Apr 25, 2012 9:27 pm
Mr Ree wrote:I had my turbine housing, exhaust manifold, down pipe and dump pipe coated at procoat and have to say I wasnt very happy with the job.
Must of been a bad day for them.
What stuff did you get put on?
Postby Mr Ree » Wed Apr 25, 2012 10:54 pm
Yeah I imagine thats all it was too, and to be honest, thats whats most annoying about it. Knowing it could have been done properly but wasnt due to being a friday arvo, or monday morning etc.
It was the high temp black satin coating and it cost about $500 if my memory serves me correctly.
wak thud gush!
Mr Ree
Postby Bazda » Wed Apr 25, 2012 11:05 pm
Mr Ree wrote:Yeah I imagine thats all it was too, and to be honest, thats whats most annoying about it. Knowing it could have been done properly but wasnt due to being a friday arvo, or monday morning etc.
When did you get it done?
They did heaps of testing on mine to get the right mixture which lasted.
They start off semi gloss then turn matt - thats normal. And or course you cant hit them into things it will chip.
Postby Mr Ree » Thu Apr 26, 2012 10:24 am
It was done at the beginning of 2009 so 3 years ago now.
And for the record, Im not a rough bugger and certainly wasnt hitting them into anything, or banging them around. I meticulously wrapped all the parts in bubble wrap before sending them to be coated, when they returned, lets just say the same amount of attention wasnt given and by the time I opened the box, there had already been multiple metal on metal contacts which lead to scratches and chips.
The bits that came into contact with studs etc, to get the manifold on the engine flaked off instatly and seemed like it was nothing more than flakey black paint, rather than a bonded coating as such.
The inconsistency to the coating confirmed for me that it wasnt coated properly/evenly, and the flaking material confirmed it wasnt prepped well enough for the coating to adhere to.
Glad to hear they worked hard for your car to get the right mix and hence ultimate job done, sadly in my case they didnt.
P.S Please dont think my post was written to slate them, I just gave my personal experience with them as I thought it was relevant.
wak thud gush!
Mr Ree
Postby gt4dude » Sat Apr 28, 2012 1:49 am
i had my manifold done at procoat with the ceramichrome,
im happy with the job done for the price, its no HPC but for half or third of the price its not half bad at all.
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
