Quick C52 trans Filler question
Postby xsspeed » Fri Apr 06, 2012 5:48 pm
Just after confirmation the top filler on the c52 is the 17mm bolt below ( if you are looking from the front of the car) what looks to be a breather?
Bolt is on the 'hump' of the selector levers
Just trying to replace fluid but I normally fill through the side hole - this has seized and the bolt is rounded. (First time in my ownership I am redoing the fluids on this one so it wasn't me lol)
Now seeing as I can't open the side hole - reckon I should fill with the 2.6L as per spec and it should be sweet?
Postby xsspeed » Fri Apr 06, 2012 6:24 pm
Here's something I prepared, is tht the filler there?
I've been learning some MSPaint skills off the master
Postby Dell'Orto » Fri Apr 06, 2012 6:34 pm
Correct. Take a bit to drain through that hole though, so be patient. Then take a cold chisel, and use it to turn the side filler bolt and buy a replacement from Mark.
Postby Bling » Fri Apr 06, 2012 7:36 pm
Can you get one of the locals to weld a nut on the rounded off bolt for you?
Postby xsspeed » Sat Apr 07, 2012 10:10 am
probably not gunna have time before track day to get a nut welded on (I am about to head away for the rest of the weekend and next week is hEkTiK- if I open the top and bottom the oil should flow out as per normal shouldn't it? It is the normal drain hole
that was my plan re cold chisel/weld a nut on
Postby QikStarlie » Sat Apr 07, 2012 10:19 am
probably fill better through the reverse switch hole.
QikStarlie
Postby xsspeed » Sat Apr 07, 2012 10:29 am
Was thinking that too but don't want oil going somewhere it shouldnt (slim chance but my luck would be it'd $&#$% something up) - will have a look at it though
Postby DexGT » Sat Apr 07, 2012 10:30 am
QikStarlie wrote:probably fill better through the reverse switch hole.
this is what I would / have done before , the "top filler" in the pic is a part of the gear change mechanism.
DexGT
Postby QikStarlie » Sat Apr 07, 2012 10:44 am
yeh, i always filled mine through reverse switch. shiny calender pages and some tape, make a sweet funnel for the job also
QikStarlie
Postby iOnic » Sat Apr 07, 2012 10:45 am
^ What I do. But I bought a $3 funnel coz I was feeling like splashing out :lol:
Postby crispy'86 » Sun Apr 08, 2012 9:22 am
I had a thought that bolt you circled was for the gear change mechanism, of all the C52/56 gearboxes i've stripped (which is 6 and counting) that was the common theme i'd found out. Was certain that helps centralise the mechanism or something along those lines.
Reverse light switch is the best way to go to fill it
crispy'86
Postby Lurkin » Mon Apr 09, 2012 11:19 pm
If its out of the car, could consider forcing a smaller socket over the bolt. I did this with an imperial impact socket back in the day.
Nothing bet a proper gearbox oil pump for refilling from there in the car. Never tried the other option. The small bottles of castrol oil have a nipple on it.. did this a couple of times. found with the castrol bottle it was easier to fill holding it from underneath the car (ae101) whereas it was easier from the top with the filler pump/gun.
Past casualties
1986 4age liftback (sold)
1985 4age aw11 (well crunched)
1993 ae101 gt apex levin (sold)
Lurkin
Postby xsspeed » Mon Apr 09, 2012 11:56 pm
Box is in car still, otherwise yeah would have tried that/tried a 6 face socket rather than 12.
Got back from easter 'holiday' - if climbing a mountain and walking 21kms is a holiday - and I attempted getting to the reverse switch, but the plug end on these is different to the ae92/101/111 boxes - makes it a c**t to get a spanner/socker/anything on. *Edit - its a black plug like in the pic above - but I can't see how to get a 25/26mm spanner onto it while in the car even with moving the cooling pipes
Just going to fill through the 17mm hole with a homemade funnel, gbox assembly pics just say its a 'plug' like the others, pulled it out and its coated in oil so I'm confident it'll be sweet (the internet also tells me it will be ok lol)
Postby Stu- » Tue Apr 10, 2012 3:33 pm
QikStarlie wrote:shiny calender pages and some tape, make a sweet funnel for the job also
Boobies calendar?
Project Thread
Stu-
Postby xsspeed » Tue Apr 10, 2012 3:39 pm
it would be a shame to get any deposits on such a page though? :lol:
Users browsing this forum: Majestic-12 [Bot] and 16 guests
