good point, just in front of the rear wheel?gmacrae wrote:fuel filter in my UCF20 basically required draining the tank, pain in the ass, wait till it's empty if its in the same spot and be prepared to catch it all
they dont make it easy eh? all the engine covers on mine make changing leads/plugs/dizzy a chinese puzzle... drives me mad, everything has to be put back in a particular order.gmacrae wrote:mine is right up high under the tank, was too tricky to plug the hose as it was pissing out so just left it to drain into a clean oil pan
Ok, so it will show more than simply bridging the terminals and doing the dashboard disco routine?gmacrae wrote:plug it in man, see what the computer says, it'll cost you ten bucks if you find a nice mechanic with a scantool
solitaire wrote:Ok, drove to work today. Exactly the same conditions and driving style.
And its missing/bucking/getting generally pissed off even more than before.
So whats next? O2 sensor(s) i guess? Or should i ditch the k&n or maybe replace the ignitors?
The leads were rooted though so good to replace them.
solitaire wrote:Ok, so it will show more than simply bridging the terminals and doing the dashboard disco routine?gmacrae wrote:plug it in man, see what the computer says, it'll cost you ten bucks if you find a nice mechanic with a scantool
My neighbour works at pitstop, maybe he has one.
Oh ok... can you point me to where I would find the testing proceedure? I don't have a 1uz engine repair manual so unsure of the proceedure.sergei wrote:Don't replace random bits... you can check O2 sensors if they are working properly (it is very easy for narrow band, not sure for wide band).
If it is missfiring, the coils might be suspect.
Ok will see what I can dig up.gmacrae wrote:not certain, but I think it will. Worth a look at least.
solitaire wrote:Oh ok... can you point me to where I would find the testing proceedure? I don't have a 1uz engine repair manual so unsure of the proceedure.sergei wrote:Don't replace random bits... you can check O2 sensors if they are working properly (it is very easy for narrow band, not sure for wide band).
No way to test coils I am guessing?Ok will see what I can dig up.gmacrae wrote:not certain, but I think it will. Worth a look at least.
solitaire wrote:Ok, I swapped the plugs and while the car seemed a bit "happier" (placebo effect?) it did not stop the missing at 50% throttle.
So a day or two ago I dismantled the maf and gave it a good going over with crc contact cleaner and so far it has not missed or hesitated.
I just filled up so will see what mileage i get out of it this time.
I also replaced the fuel cap gasket which i believe was not sealing, given that it takes me a good 3 weeks to go through a tank of gas i wonder if it was evaporating as well?
sergei wrote:solitaire wrote:Ok, I swapped the plugs and while the car seemed a bit "happier" (placebo effect?) it did not stop the missing at 50% throttle.
After cleaning MAF it is good idea to reset ECU to get rid of dodgy long term fuel trim maps.
solitaire wrote:sergei wrote:solitaire wrote:Ok, I swapped the plugs and while the car seemed a bit "happier" (placebo effect?) it did not stop the missing at 50% throttle.
Oh good suggestion, i cleared it recently but did not do it after cleaning the maf. I will do that before i drive home, 30 seconds should do it right?
Good question, i have no idea where it would be, the engine bay is full. According to the toyota book it should be where the battery is located, but then if i look at the next model up (20 series) it should be under the battery - my car seems to be a bastard hybrid of the ucf10 and 20 in a lot of ways and I know there were '94 ucf20's as they changed model at the end of '94.RomanV wrote:Someone might have put the hole in the fuel cap if they had removed the charcoal cannister setup etc...
Is all that still there?
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot] and 22 guests
