Help: Unknown random Camry hesitation - Video
Postby tiny2009 » Fri Apr 27, 2012 6:24 pm
Welcome, long story short:
- Looking after camry for family which is an Aussie built 1994 Camry Wagon 2.2 manual 5S-FE
- Fault has been with car since it was purchased 2+ years ago
- Been to toyota to check for faults, nothing found
- Checked myself by using the paper clip method, nothing found
- Service history is pretty unknown but had oil + filter regular in last few years
- Fault seems to happen when A) Has been raining or washed B) when cold, generally more reliable once its hot. Possibly gets worse with many short trips
Video below is a clip of what it does. Note this can happen while driving and seems random. It will hesitate and rev counter goes mental. Before I go trying to find the source someone may be able to point me in some sort of direction.
Possible thoughts are:
1. Earthing
2. Coils, leads, plugs?
3. ECU
4. Fuel (filter or other?)
5. Gremblins
6. Built in Aussie
Thanks in advance.
http://youtu.be/5CIVChLjTrg
tiny2009
Postby RS13 » Fri Apr 27, 2012 7:38 pm
Hmm, maybe earthing.. have you tried adding a ground to see if it helps, jumper lead etc? I've known quite a few Hondas to have a similar fault, normally caused by old loose/arcing wiring inside the distributor.
RS13
Postby matt dunn » Fri Apr 27, 2012 9:44 pm
replace the dist. very common and there is not much else common that will affect the tacho.
Postby Rob » Sun Apr 29, 2012 12:37 pm
Check the ecu number, there is one for oz built camry's which has a fault.
If you post the number I will recognize it.
Also the IAC plays up as well. Need to pull the the throttle body apart and clean all the carbon out
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby tiny2009 » Sun Apr 29, 2012 8:05 pm
Cheers guys, I will work my way through the list above and let you know how it goes.
tiny2009
Postby Crucible » Sun Apr 29, 2012 8:24 pm
matt dunn wrote:replace the dist. very common and there is not much else common that will affect the tacho.
+1
Crucible
Real Life Mechanic
