Too much toe? Wheels spaced?
Postby TRD_ZERO » Sun Apr 29, 2012 7:44 pm
I converted from superstrut to McPherson and now both the front wheels are sticking out as if the steering rack is too short.
I'm using the super strut rack ends and didn't remove or adjust them just popped them out of the hubs. They are quite visibly off when the wheels are off.
Has anyone done this or know if this happens when doing this conversion? Mane the mounting point on the hub arnt in the same spot.
Also how much adjustment are in the rack ends because I want to wind them out but worried there isn't enough thread to do so safely?
Previous:
TRD_ZERO
Postby molex » Sun Apr 29, 2012 7:49 pm
Rack ends and tie rods are hugely different! You can buy non superstrut stuff and put onto the original rack and will get you ballpark correct.
molex
Postby Lloyd » Sun Apr 29, 2012 8:00 pm
Have you got the non-SS ones to compare? The tie rod ends/rack ends usually thread together anywhere between 12-20 turns.
Postby TRD_ZERO » Sun Apr 29, 2012 8:58 pm
I do have both sets. But don't want to take the ss ones off if I don't have to.
I've been told that I can use the ss ones with the McPherson setup.
I know I can just adjust them but not sure to what extent.
So about 12-20 turns until they come off? how many turns from completely off if safe? Just so I know my limit until I have to completely change them.
Previous:
TRD_ZERO
Postby KIPH8N » Sun Apr 29, 2012 10:43 pm
Iv done mc pherson strut conversion on mine two weeks ago and i had to change the power steering rack.
Previous:
1991 Levin GT Apex (SS) Manual
1991 Levin GTZ (SS) Manual
1995 Toyota Levin BZV (SS) Manual
1997 Toyota Corolla BZ Touring Manual
1998 Trueno Bzr SS to Mcpherson 4agte
1997 Toyoya Chaser 1jzgte Factory Manual ;)
1998 Nissan Primera Autech SR20VE
Contact 0211779879
Email nameetn@hotmail.com
Facebook: Navneet Nand
KIPH8N
Postby allencr » Mon Apr 30, 2012 11:38 am
TRD_ZERO wrote:Also how much adjustment are in the rack ends because I want to wind them out but worried there isn't enough thread to do so safely?
1.5 to 2 times the diameter: 10mm threads need 15 to 20mm engagement. If the rod ends use a jam nut, that is plenty, but if it is the type with a split sleeve & clamp, I'd go for 5-10mm past the clamp.
Just do it or you will never know. No one else knows what your combination of
original, & OEM aftermarket & whatever will equal.
allencr
Postby molex » Tue May 01, 2012 1:21 am
I put a SS AE111 rack in my AE92. No way in hell superstrut rack ends/tie rods was going to work. I swapped to new AE92 stuff and it's aligned up well.
Just buy the correct bits and it works with the original rack I'm sure.
molex
Postby Bazda » Thu May 03, 2012 9:26 am
Yep you need to swap to the non SS steering arms.
Pretty easy to do.
Postby Shrike » Thu May 03, 2012 9:30 am
so go from the bananna tie rod ends to the non s/s tie rod ends ? Ive got the s/s ends still on and havent noticed any difference (in saying that I want more caster camber and toe adjustment anyway lol and the cars on stands atm)
Shrike
Postby TRD_ZERO » Sun May 06, 2012 6:27 pm
I wanted to keep the banana rod ends and just wind them out until the wheels lined up. I did that yesterday but to get the wheels to sit straight the arms would only have 3 complete 360 degree turns from off which in my mind just doesn't sound safe to run. Some of my friends think otherwise.
So I'm going to have to run the McPherson arms and ends.
Also now looking at the car the right hand wheel seems to sit out further than the left as if I'm running a spacer?
WTF is going on? How did this happen? I'm going to have to look into it when I get the chance.
Any ideas what could have caused this?
Previous:
TRD_ZERO
Postby Bling » Sun May 06, 2012 6:46 pm
TRD_ZERO wrote:Some of my friends think otherwise.
Glad to hear you ignored them 8O
