door swaping - toyota corona
Postby NOLAW » Sun Apr 29, 2012 11:27 pm
ok long story short someone backed into my rear passenger door on my 95 corona, iv found a replacement door but it has electric windows and mine has manual ones, can i still use this door and set up my manual window winders or am i better off finding a door with manual window winders?
NOLAW
Postby NOLAW » Mon Apr 30, 2012 9:11 pm
anyone?
NOLAW
Postby Makaveli » Mon Apr 30, 2012 9:59 pm
You can try swapping the inside bits like the inner door panel and the glass mechanism etc. Probably would be easier to get a manual wind up door from the start. Not sure sorry. I think it probably can be done, but might be too much headache for what its worth.
Makaveli
Postby matt dunn » Mon Apr 30, 2012 10:03 pm
I cant be 100% sure but I would expect that swapping the window and regulator would be quite easy and the mount would be the same.
It would surprise me if it would not work.
Postby ch4ng » Tue May 01, 2012 11:40 pm
or wire up the electric windows?
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby magweal » Wed May 02, 2012 12:17 am
If they are the same as the ae101 corolla and they should be, just swap out the regulator for the winder and the wiring harness although that wouldn't matter, just make it neater. The mounting points would be the same.
98 BZ-T rola SMUGLN V1(RIP)
97 NZ new GL rola now with BZ transfer 80%
magweal
Postby andyztouring » Wed May 02, 2012 5:39 pm
Its a simple straight forward swap over job.The holes in the door are all there for both electric windows or manual windows.
andyztouring
Users browsing this forum: Majestic-12 [Bot] and 33 guests
