Stott69 wrote:Na, no flat walls at home n I had them set last wof cause they were to high.
Adoom wrote:I'm sure there will be a flat wall somewhere near your house
Last time I did it, I think the wof guy said the high beam should be 100mm higher than the headlight for every metre away.
It was ages ago, but I think those were the measurements.
Someone correct me if I'm wrong.
matt dunn wrote:Adoom wrote:I'm sure there will be a flat wall somewhere near your house
doesn't sound right to me.
We set them 0.5% down on high beam and 1.5% down for low beam.
pc wrote:Assuming your beam adjusters work, just tell the WOF guy to set them to where he is happy with... why piss around setting it yourself?
Return to Wellington / Lower North Island Region
