New info regarding welding forged/cast suspension compents.
Postby RobertC » Wed May 02, 2012 5:50 pm
Here is a copy of the new information sheet. Couldn't find this on there website so have put it here for others to read.
As far as Toyota goes. Superstrut and ae86's will be effected. And any others that use cast suspension components.
This only applies to aftermarket suspension that needs certification.
Reference is made to approved manufactures. From what I understand major manufactures such as Tein and Bilstein are currently not approved.
This has come to my attention after trying to certify some coil overs of the aforementioned brand and failing for the reasons set out in the information sheet.
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Postby 1I1 » Wed May 02, 2012 5:56 pm
Were Autolign able to get hold of any technical info for you Rob?
TRD Clicky >>Here
1I1
Postby RobertC » Wed May 02, 2012 6:08 pm
1I1 wrote:Were Autolign able to get hold of any technical info for you Rob?
Thus far they have been helpful. I've been told they are waiting to hear back from Tein Japan but currently they are on holiday. I'm surprised that I'm the first person that has contacted them though.
RobertC
Postby gt4dude » Fri May 04, 2012 6:52 pm
my BC coilover for st205 is like this, the superstrut bottom is cast, but the strut tube is mild steel, you have to leave about 15mm of mild steel tube, then the BC coilover sits inside the tube and you weld to the mild steel
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby Bazda » Fri May 04, 2012 8:24 pm
gt4dude wrote:my BC coilover for st205 is like this, the superstrut bottom is cast, but the strut tube is mild steel, you have to leave about 15mm of mild steel tube, then the BC coilover sits inside the tube and you weld to the mild steel
This is how custom coilovers have been made for years on race cars.
AE86, Capri, Escort etc etc
With the new rules it will most likely fail unless you want to pay $1300 to get your item destroyed while they test it.
Postby xsspeed » Fri May 04, 2012 8:38 pm
I havent read all of the above article, but my understand (at least previously) was for say the ae86 spindles, so long as the strut was welded over the stub - ie mild steel, and not to the cast hub/spindle it was certable.
In toyota circles at least the issue with the ae86's coilovers is they are welded to the cast element, not over the stub. From memory some of the coilover manufacturers still allow you to buy the strut and you can (get someone to) weld them on over the stubs?
Postby Bazda » Fri May 04, 2012 9:01 pm
xsspeed wrote:I havent read all of the above article, but my understand (at least previously) was for say the ae86 spindles, so long as the strut was welded over the stub - ie mild steel, and not to the cast hub/spindle it was certable.
Yep they all used to pass before as long as you showed the certifier how you did it and used a welder who had his tickets etc.
But after reading this which has been only introduced in March 2012 looks like everything will have to be tested.
Postby wde_bdy » Fri May 04, 2012 9:17 pm
For Toyota stuff (AE86 etc) if you use a factory strut and weld ABOVE the casting to the original strut tube, then it can be certified (generally after xraying) as you are not welding to a cast steering component. If you weld a new tube direct to the factory cast hub or use an aftermarket complete strut unit (that incorporate the cast hub) then no it can't be certed without destructive testing or evidence of such testing.
Callum
wde_bdy
Postby xsspeed » Fri May 04, 2012 9:17 pm
after a skim read - won't testing for welding to mild steel still be the same?
Ie - ticketed or good welds, verified via NDT - which costs like $150?
The issue remains welding to the casting
Postby Bazda » Fri May 04, 2012 9:19 pm
wde_bdy wrote:For Toyota stuff (AE86 etc) if you use a factory strut and weld ABOVE the casting to the original strut tube, then it can be certified (generally after xraying) as you are not welding to a cast steering component. If you weld a new tube direct to the factory cast hub or use an aftermarket complete strut unit (that incorporate the cast hub) then no it can't be certed without destructive testing or evidence of such testing.
Callum
This makes sense.
Postby xsspeed » Sat May 05, 2012 10:42 pm
Callum
This makes sense.
Yeah thats what I was trying to say, NDT = non destructive testing, ie ardrox dye penetrant + photos iirc
