Alloy mounting radiator questions
Postby mlewis » Mon May 07, 2012 2:22 pm
Looking to find a simple way to mount my alloy radiator to my project ae111 levin, have the radiator and found where to to mount it but looking at peoples ideas on mounting. Also can i use a brand new oil catch can as a over flow bottle, its got an inlet in the side top and a drain in the bottom, also has a small pipe in top where you can fit the breather filter. Any help and ideas is very appreciated
mlewis
Postby TRD_ZERO » Mon May 07, 2012 7:06 pm
Is it a direct replacement?
I've got one for my ae111 suited for a ae111 and fits with the factory brackets
Previous:
TRD_ZERO
Postby mlewis » Mon May 07, 2012 7:10 pm
I've got the radiator already, just need some advice on mounting. its a honda half size style alloy radiator, thinking about finding a honda that had the half size radiator and reusing the mounts on my levin
mlewis
Postby Quint » Mon May 07, 2012 10:06 pm
Dowels on the bottom line up with the mounting holes? Should, move them if they don't.
Get some 3-5mm alloy, cut out a strip ~25mm wide and bend it into a U with a tab to bolt to the car. Glue some conveyor belt rubber (heavy rubber) to the inside of the U, Bolt it on, done.
Quint
Postby mlewis » Mon May 07, 2012 10:22 pm
so i don't have to use the little dowel holes in the top of the radiator? they just seem so dicky to use. there are holes in the bottom of the front bar already to mount brackets on, so alloy plat with a u sounds perfect.
Any advice and ideas of using the catch can as an overflow bottle?
mlewis
Postby cat007 » Thu May 10, 2012 12:19 pm
I mounted mine up top like this. The bottoms sit into the existing radiator holes thought.
Postby Quint » Thu May 10, 2012 12:38 pm
Heh, exactly how i did mine... except i rounded off the square edges :p
Quint
Postby cat007 » Thu May 10, 2012 1:59 pm
haha yeah. I'm not so concerned with pretty....obviously lol
Postby nz_climber » Thu May 10, 2012 9:06 pm
Here is how I mounted mine
Top
Bottom
I am sure you could use a catch can as an overflow (I used a $7 drink bottle from mitre 10 mega) but remember the pipe from the radiator must be submerged below the water level .
nz_climber
Postby mlewis » Thu May 10, 2012 9:24 pm
thanks for the help guys
have used your idea of a alloy strap bend into a L at the end with a piece of rubber super glued on the end to make it snug, atm its only 1 on top one on bottom as the other side of the bottom sits on by middle chassis rail that runs through my engine bay.
will just go to pick a part and find a very small overflow bottle to reuse, prob something from a honey city or similar tinniness lol
mlewis
Users browsing this forum: Majestic-12 [Bot] and 22 guests
