Where to buy Press in Studs
Postby Allister S » Tue May 08, 2012 4:11 pm
Hey,
Anyone know where I can get press in studs (like, but NOT wheels studs) like the ones used in Strut tops/Camber tops and Lower arm ball joints. They have a flat round head and splines at the base of the stud before the thread starts.
I need some M12x1.25 about 35mm long
Thanks, Allister.
NZ AE82 GL Liftback Tarmac Rally spec
NZ AE82 GT Liftback x 2
R32 Skyline GTS-t Type M Coupe
'07 Subaru Legacy GTB
'03 Runx 2ZZ-GE 6spd
Allister S
Postby THA SHZ » Tue May 08, 2012 5:54 pm
hey allister have you tried bolt shop in archers rd ? they normally have or can source whatever i need 8)
THA SHZ
Postby ee904age » Sat May 12, 2012 6:22 pm
why not wheel studs? These guys have exactly what you want (except they are 41mm overall) but they ARE wheel studs?
http://cmtrailer.co.nz/hubs-stubs/studs-nuts
Buy via BNT
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby touge_ae101 » Wed May 16, 2012 1:45 pm
in that size just pull some studs out of the rear hubs of a corolla of some description, they are 35mm long and m12x1.5. win. rear studs are 5mm shorter than fronts for some reason..
touge_ae101
Postby DRFTIN » Wed May 16, 2012 3:35 pm
just had a look on the shelf and we have 33, 34 and 37mm. suzuki wheel studs
i was going to use one of our 10mm ones for a strut top a while ago, was nearly identical
DRFTIN
Postby Allister S » Thu May 17, 2012 2:31 pm
Thanks for all the tips guys!
Unfortunately no press studs from the Bolt shop.
Trailer studs looked promising but thread must be fully formed by 10mm under the head - doesn't look like that'll quite be the case.
Suzuki wheel studs might be be good. Does the thread start at less than 10mm under the head? Is the Knurl Diameter small like 12.85mm?
These are actually for Toyota Lower arm ball joints - I've pressed out a couple but was wanting new ones as the knurling is pretty wrecked. I've found part numbers for Toyota ones but only 10mm knurled studs!!
Thanks. Cheers, Al
Allister S
Postby DRFTIN » Thu May 17, 2012 4:17 pm
suzuki ones i have here all have a knurl of about 12.5mm, thread starts about 12.5 from the head
so probably no use either
DRFTIN
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 23 guests
