4AGE starters
4AGE starters
Postby Vertigo » Mon May 14, 2012 11:47 am
is there a difference between RWD and FWD starter motors for 4AGE engines? can they both be used in either configuration?
TVIS just kicked in, yo!
Vertigo
Postby AE86less » Mon May 14, 2012 5:08 pm
I was led to believe that there wasn't and I can't see any reason that they would be different.
Having said that, the (originally fwd) smallport in my AE85 (using A/M bell and W55 with original smallport flywheel and starter) made a horrible noise which disappeared when I swapped it for an AE86 one.
Hope that answers your question :lol:
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby matt dunn » Mon May 14, 2012 6:25 pm
There are three types of starter,
Convention
Gear reduction
and Planetry gear,
and two different mounts,
Mounts 1 one suits 16V 4age and AW11 GZE,
and Mount 2 suits the 20V and the late GZE,
so 6 different basic combinations of starters,
and a few small differences in them that most wont notice.
But all the mount 1's interchange
and all the mount 2 types interchange.
Postby sergei » Mon May 14, 2012 6:28 pm
matt dunn wrote:There are three types of starter,
Convention
Gear reduction
and Planetry gear,
Does mount 2 goes on intake side and mount 1 on exhaust?
Also what is better conventional gear or planetary?
Postby jaypines » Mon May 14, 2012 6:38 pm
Convention
Gear reduction
and Planetry gear,
i think planetary or the reduction gear would be better because of the reduced current needed to get them going...
jaypines
Postby matt dunn » Mon May 14, 2012 6:46 pm
Yeah basically an intake side mounted one and an exhaust side mounted one.
The conventional is the older type,
and the gear reduction is much better but quite bulky stil.
the planetry gear type is the best as it has a lot more torque and is quite compact.
The planetry type was still used until at least late 2000's on different engines and may stillbe used as I have not seen a toyota type more modern yet.
Postby rollaholic » Mon May 14, 2012 9:38 pm
i put a smallport (fwd obviously) reduction type starter on my rwd bluetop without issue
Postby cat007 » Mon May 14, 2012 9:46 pm
Planetary are the ones that have a solenoid and generally the teeth aren't spinning much before they make contact with the ring gear?
And the other sort is the where the starter gear is on some sort of system as the motor turns the gears twist out like a screw?
Users browsing this forum: No registered users and 33 guests
