link ecu and msd coil
Postby tim_blair » Sat May 19, 2012 1:17 pm
have a link G4 storm and im wanting o upgrade my coil with an msd one does any one know of any problems i may have this is the coil i am thinking of using
"Pro Power HVC Coil, Use w/MSD 7 Series, Part No. 8251"
girl: can I trust you?
me: you can trust anything :D
tim_blair
Postby matt dunn » Sat May 19, 2012 7:28 pm
Do you know what MSD stands for?
Postby tim_blair » Sun May 20, 2012 3:02 am
enlighten me
tim_blair
Postby 85AW20v » Sun May 20, 2012 9:16 am
See ya
Simon
85 MR2 20v
85AW20v
Postby matt dunn » Sun May 20, 2012 9:26 pm
A coil designed for a MSD ignition system is only compatable with a MSD system,
Which is different than an MSD coil designed to replace a standard coil on a standard system.
Postby tim_blair » Mon May 21, 2012 8:04 pm
these are the two coils im looking at buying
the first is the one i want but it says in its instructions that its only for use with an msd ignition,
the second says that it can be used with any factory or aftermarket ignition
they are both the same price
1: Pro Power HVC Coil, Use w/MSD 7 Series
Part No. 8251
http://www.msdignition.com/Products/Coi ... eries.aspx
specs
Turns ratio: 85:1
Primary resistance: .04 OHMs
Secondary resistance: 86 OHMs
Inductance: 1 mH
Maximum voltage: 45,000 Volts
Peak current: 1.1 Amp
Spark duration: 150 uS
2: Blaster HVC, Works w/ MSD 6 Series Units
Part No. 8252
http://www.msdignition.com/Products/Coi ... Units.aspx
specs
Turns Ratio: 100:1
Primary resistance: .02 OHMs
Secondary resistance: 1.38K OHMs
Inductance: 7 mH
Maximum voltage: 42,000 Volts
Peak current: 300 mA
Spark duration: 200 uS
both coils look the same
can anyone give me any reason why the first is said to only be used with MSD ignitions
tim_blair
Postby QikStarlie » Mon May 21, 2012 9:15 pm
because this:
85AW20v wrote:Multiple Spark Discharge.
what are you trying to do, what engine & setup?
obviously your running a dizzy setup.. better off ditching that and going wasted spark or cop. than buying some shiny red coil
QikStarlie
Postby matt dunn » Mon May 21, 2012 9:39 pm
Primary resistanc of both is way too low,
would last about 10 seconds before it blows a fuse, melts the igniter, or both.
A good electronic ignition coil is about .8 ohms.
12v at 0.8 ohms is about 15 amps
12v at 0.04 ohms is about 300 amps
12v at 0.02 ohms is about 600 amps
Going to put a 600A fuse in there???
Postby tim_blair » Mon May 21, 2012 10:03 pm
its on a BT 4age(heavily modded)(toda OS pistons, toda cams etc)
with link G4 storm
factory coil, igniter and dissy
how does the igniter work and what is its purpose?
what coil would you suggest?
what should i be looking for when selecting a coil?
tim_blair
Postby matt dunn » Mon May 21, 2012 10:19 pm
everyone will probably reccomend something different,
but i would go for something like this
http://www.trademe.co.nz/motors/car-par ... 978545.htm
HEC715 bosch,
but then you will not get an HT lead that will fit that and the 20V dist cap,
will have to make one.
The standard 20V coil will be way more than adequate,
But i'd be suspect on the toyota igniter.
we have not had much luck with toyota igniters and aftermarket ecu's
as the toyota igniter is more of a module than an igniter,
it has too many functions in it like dwell control and similar,
better to go for a so called 'dumb' igniter like a a J121.
have a read through all this
A J121 is pictured 1/2 way through.
http://www.dtec.net.au/Ignition%20Coil% ... ration.htm
Postby QikStarlie » Mon May 21, 2012 10:38 pm
should run fine on stock ignition, as above.
have ran the toyota ignitors without any issues on a few link setups.
another option is these: http://www.trademe.co.nz/motors/car-par ... 649510.htm.
probably whats inside the bosch j121 above.
i'd probably still switch to a wasted spark or cop setup. easy to setup with your link.
QikStarlie
Postby tim_blair » Sun May 27, 2012 5:03 pm
tim_blair
Users browsing this forum: Google [Bot] and 24 guests
