Ovel port intake manifold on rectangle G head?
Postby bzrspeed » Fri May 25, 2012 8:42 am
Hello
Can this be done? I have oval intake manifold and want to match with rectangle g 16v head. Can it be done or will it cause vacuum and loss of pressure? Other option is to cut intake manifold and wield modified g 16v flange on.
bzrspeed
Postby Vertigo » Fri May 25, 2012 10:14 am
is it a 4AGE? rectangle intake port sounds like its a 4AFE
TVIS just kicked in, yo!
Vertigo
Postby bzrspeed » Fri May 25, 2012 11:27 am
It is 4age series 2 small port version from EE100 Corolla GT-z model which had supercharger induction. I am trying to match up ford BDA manifold to it, the bolts are identical just ford head ports are round and Toyota are rectangle.
bzrspeed
Postby RomanV » Fri May 25, 2012 11:36 am
Well it's not going to be ideal.
But are you wanting to do your BDA replica type thing with low power anyway?
If so, it's probably not going to matter.
Postby Vertigo » Fri May 25, 2012 11:40 am
tbh id just get a smallport intake manifold..
Vertigo
Postby Dell'Orto » Fri May 25, 2012 12:19 pm
Is there room in the manifold to port it out then build back up in the correct shape with epoxy?
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
