Foot wells in race car
Postby captain crescent » Sun Jun 03, 2012 7:31 pm
Ok so I'm in the process of weight reduction and tidying the interior my race car.
Originally in the foot wells it had 4mm alloy checker plate. It was a rally car but I have converted it to a track hack. What have you seen or recommend? I was thinking of a grip tape or paint but I am unsure so suggest away.
Budweiser is a gay beer. if it isn't a gay beer Sam why are you trying to put it up my arse.
captain crescent
Postby d1 mule » Sun Jun 03, 2012 9:54 pm
the floor of the car works pretty good.......
d1 mule
Postby Dell'Orto » Sun Jun 03, 2012 9:58 pm
Checker plate is good, but you need to be careful with how much NOS you run
Postby gt4dude » Mon Jun 04, 2012 7:30 pm
Dell'Orto wrote:Checker plate is good, but you need to be careful with how much NOS you run
He's right, the checker plate might fall through the car and scrape along the ground before being ejected at high velocity from the underbelly leaving a big gaping hole in the cabin ;D
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby AE86fan » Mon Jun 04, 2012 7:40 pm
I had a sparco foot rest in the passenger footwell of my rallycar and it worked well, especially if the seat is along way back and your co-driver wants something to help them support their weight. I generally reckon any sort of alloy plate in the foot well is just for looks but I did hear of someone a few years ago that got a strainer post through the floor after going off the road.
1984 NZ AE86
AE86fan
Postby Bling » Mon Jun 04, 2012 7:41 pm
I would have thought paint and grip tape would be a pretty good solution as you say.
www.motecgriptape.com has some cheap deals on tape.
Postby .:O4AGTZ:. » Tue Jun 05, 2012 1:48 pm
DANGER TO MANIFOLD
.:O4AGTZ:.
Postby crispy'86 » Tue Jun 05, 2012 1:59 pm
I've seen Hammerite or a similar product with that built into the texture of the paint. Like rough dimples or similar so that could be an option.
crispy'86
Postby Alex B » Tue Jun 05, 2012 2:56 pm
Hammered finish? I wouldn't say you would get very good grip off that, be better off using a smooth finish with 3M grip tape.
Postby xsspeed » Tue Jun 05, 2012 3:07 pm
or mix grit (or other media) with paint
Postby ch4ng » Tue Jun 05, 2012 6:25 pm
BZGBling lol
just paint it and sprinkle some sand on.
I have seen some stuff at Mitre10 that you can mix with paint to give it more grip, they use it on outdoor ball courts. just ask the staff
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby Leon » Tue Jun 05, 2012 6:31 pm
I just put the carpets back in my race car :)
Postby crispy'86 » Tue Jun 05, 2012 8:44 pm
Alex B wrote:Hammered finish? I wouldn't say you would get very good grip off that, be better off using a smooth finish with 3M grip tape.
Wasn't exactly a hammered finish as such, the product i'd used was flakey like it had sand in the spray can. Used it on my trueno in an incospicuous plcae to get it white and thought "Man this is so rough"
crispy'86
Postby TRD Man » Fri Jun 08, 2012 12:28 pm
It's good to have something there to stop your feet slipping about.
Have a look at the stick on stuff that they apply to skate boards. You could probably buy it quite cheaply and it'd weigh nothing.
It seems to last forever but if it does wear out replacing it would be easy.
TRD Man
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 27 guests
