bzrspeed wrote:Английские девушки это хорошо, но русские девушки горячее!
RS13 wrote:Also, ATF is another good one I've heard of..
Lloyd wrote:Had to do it once to mine, was more due to a lazy battery. If they don't start first go then they have a tendancy to flood which causes the compression loss. You don't need to take the plugs out. There are vacuum ports on the size of the intake runners, just run a vacuum hose into a container of brake fluid on each rotor in turn and crank it for a little bit. Sucks up some fluid, compression is back and away you go.
But yes, smoke.... The old garage was under the house and the flatmate thought the house was on fire
Users browsing this forum: No registered users and 70 guests
