NZKW Race Seats - Anyone used one?
Postby Mr Revhead » Mon Jun 18, 2012 9:47 pm
Dell'Orto wrote:How tall? I'm 6'1ish, and fit them fine...though are you meaning with harnesses?
You're also made 3/4 width :P
Postby Looonie » Mon Jun 18, 2012 10:54 pm
strx7 wrote:that the harness holes are high enough up that they dont compress you spine when you pull the harnesses tight
On this note, can anyone recommend some seats that aren't made for midgets who had their legs cut off at birth? Every single race seat I've sat in, the harness holes have been below my shoulders... I just figured it was something I'd have to live with, but now I'm a little worried...
Rumple dee pumple dee doo...
Looonie
Postby strx7 » Mon Jun 18, 2012 10:58 pm
how tall are you Loonie?
Postby TTEETT » Tue Jun 19, 2012 11:29 am
Sabelt Titan size L if you are 80-90kg and 6 foot or taller, Titan XL if you are more 100kg and 6 foot or taller.
I am 6 foot and 95kg, stocky build, mine are the XL but would probably go the Large if I was to replace them. They are 9kg so quite light for a XL seat, the L is lighter. They have big harness holes so are quite adjustable. Best seat sub $1000 IMHO.
TTEETT
Postby Looonie » Tue Jun 19, 2012 9:49 pm
I'm only 6'6"... fairly substantial build too :D
Looonie
Postby Bazda » Wed Jun 20, 2012 11:44 am
strx7 wrote:
Bazda wrote:If you can find Racepro they are also really well priced.
I got mine for like $350 each from Repco on special!!!
racepros are OK if you are small, if you are a taller person racepros are too small
They have their Large size. IH8TEC had one on this forum and he was around the 90kg mark and fitted them with room to spare.
I've got the small one and yes its only intended for a slim build person for sure!
http://www.racepro.co.nz/seatdimen.htm
Postby touge_ae101 » Wed Jun 20, 2012 11:46 am
try a racetech RT1000. the newer ones are a bit more forgiving than the older ones. other than that i would recommend a racetech 4000W or a sparco evo XL. both very comfortable seats could spend all day in them!
touge_ae101
Postby strx7 » Wed Jun 20, 2012 11:52 am
I looked at that info a couple of days ago and just like the sabelt site, they dont provide harness to seat base measurements like Racetech and others do.
he might be 90KG but how tall is he?
for other peoples reference
Postby TTEETT » Wed Jun 20, 2012 12:32 pm
Looonie wrote:I'm only 6'6"... fairly substantial build too :D
You are a giant! Maybe look at basketball instead of motorsports :lol:
If you are local you are more than welcome to try my seats out, maybe at a Toyspeed Trackday or meet, they are very generous :)
GL
TTEETT
Postby Looonie » Wed Jun 20, 2012 8:25 pm
GL
Hahah cheers, damn you I was local until today :P
I've sat in Gina's Sparco Evo XL and it was nice and comfy, but I still think the harness holes were a little low. Those are the seats I'm probably going to aim for though.
A few years ago I took all the relevant measurements for seating, I'll have to find my book and hunt them out... its the base to harness hole thats the biggest problem for me.
Looonie
Postby DexGT » Wed Jun 20, 2012 11:34 pm
With racetech seats being made here they can make them to suit. A guy in the car club had one made with the seat belt holes higher for this very reason.
DexGT
Postby Looonie » Thu Jun 21, 2012 10:23 pm
DexGT wrote:With racetech seats being made here they can make them to suit. A guy in the car club had one made with the seat belt holes higher for this very reason.
Yeah I investigated that option a few years ago, off the top of my head it was nearly double the price of a normal seat to get that done, and I just wasn't as impressed by the 4000W as I am by the Sparco Evo XL.
Looonie
Postby TTEETT » Mon Jun 25, 2012 10:19 am
Racetech are very good and I am all for supporting NZ made but when I costed mine up I could save myself around 1,000 buying the Italian made and lighter Sabelts.. $1000,00 is a lot when you are on a budget!
TTEETT
Postby Looonie » Sun Jul 08, 2012 12:04 pm
So did some quick measuring again, looks like harness holes being about 690mm high is what I need...
Racetech 4000WX looks to be about 2cm too short, can't find the specs for the Sparco EVO seats.
Looonie
Postby Looonie » Sun Jul 15, 2012 7:10 pm
Well after some driving around and sitting in a 4009WHR and a Sparco Evo 3, my choices seem to be either pay $1700ish for a custom modified 4009W, or just under a grand for a Sparco Ergo.
I felt the Evo 3 lacked lateral thigh support and wasn't a deep enough seat, Sparco Ergo looks better in that respect, although I'm not a fan of the head restraints.
Annoying how some manufacturers only list the total height of the seat rather than base to harness hole measurement.
Looonie
Postby 85AW20v » Wed Jul 18, 2012 10:06 pm
Looonie wrote:So did some quick measuring again, looks like harness holes being about 690mm high is what I need...
Looks like Racetech now do a seat for tall and tall and wide people - RT4009THR or WTHR. http://www.racetech.co.nz/racetech.shop/index.php?main_page=product_info&cPath=65&products_id=422. Says the harness holes are at 71cm from the base so might be OK for you. It's measurement G that you need to check. There are others as well apart form the one I've linked to.
See ya
Simon
85 MR2 20v
85AW20v
Postby Looonie » Thu Jul 19, 2012 9:59 pm
Cheers, yeah me and the guy at Chicane discussed that while I was there, but didn't seem to think it would be tall enough for me. He actually rang his Racetech rep to discuss it, their suggestion was solely to custom modify a 4009 for me (they can only custom modify this model). Interesting how you say 71cm to harness holes, I should probably get along to Speedshow and visit the Racetech stand, hopefully they have one there, although I'd hate to think what the cost of it will be.
Looonie
Postby strx7 » Thu Jul 19, 2012 10:07 pm
a std 4009HR is $1380 from NZ Performance wholesale
Postby TTEETT » Fri Jul 20, 2012 10:09 am
Looonie wrote:I should probably get along to Speedshow and visit the Racetech stand, hopefully they have one there, although I'd hate to think what the cost of it will be.
That's a good idea, they have all the right people there to answer your questions.
Check out the autoquip stand too, talk to Chris about big seats, he is ontoit.
TTEETT
Postby Looonie » Fri Jul 20, 2012 11:38 am
strx7 wrote:a std 4009HR is $1380 from NZ Performance wholesale
I sat in the 4009WHR, barely squeezed in and the harness holes were around where my shoulder blades sit.
Looonie
