Can I dismantle seatbelt buckle?
Postby ollieboy » Tue Jun 19, 2012 7:54 pm
New Question: Am I able to dismantle seatbelt buckles? The switch inside jams so my seatbelt light does not come on.
Picture of buckle attached:
As you can see the switch does not come all the way out. Other than that the buckle works fine. Holds seatbelt securely and is not unsafe.
Thanks,
Ollie
ollieboy
Re: Can anyone identify this? Also seatbelt lights.
Postby 85AW20v » Tue Jun 19, 2012 10:55 pm
ollieboy wrote:Hey guys,
I have two questions. The first is regarding this box I found under my driving seat. Is it for keyless entry?
Also my seatbelt light isn't working in the dash. I have a wiring diagram and it looks like this:
What do the arrows mean on 1e, 3a and 3c.
Thanks for your help.
It's the controller for your seatbelt light on the dash :D
No idea on the arrows.
Sorry, couldn't resist that......
See ya
Simon
85 MR2 20v
85AW20v
Postby ollieboy » Tue Jun 19, 2012 11:22 pm
Haha, :D
On closer inspection, it looks like a mini nuclear power plant.
ollieboy
Postby Mr Ree » Tue Jun 19, 2012 11:28 pm
That looks like the factory keyless entry found in some jza80's so odds on it being the same are pretty high :)
wak thud gush!
Mr Ree
Postby ollieboy » Tue Jun 19, 2012 11:37 pm
Cool thank you. I thought it must have been but wanted to make sure.
ollieboy
Postby sergei » Wed Jun 20, 2012 9:35 am
arrows are just connectors.
check if the seat belt switch is connected under seat.
That controller is definitely some radio device, which suggest keyless entry.
Postby ollieboy » Wed Jun 20, 2012 2:50 pm
Ok cool. Thanks for that.
Everything is connected for the seatbelt light and is showing current. I can get the light to turn on by bridging the two terminals on the clips. There is no current flowing through the buckle though so I think it must be a switch inside the buckle. Do you know if these are serviceable?
Picture of buckle attached.
Edit: Mostly solved. Title and original post now edited. :)
ollieboy
Postby matt dunn » Wed Jun 20, 2012 6:32 pm
Stupid question but why do you want the light to work?
We remove them all the time at work.
Matt
Postby ollieboy » Wed Jun 20, 2012 6:38 pm
Because I am OCD :)
I'm just fixing up everything in the car and it is one of the things I want working. Not for any particular reason though.
ollieboy
Postby DVSMOTORSPORT » Thu Jun 21, 2012 8:47 pm
The belt buckles are not servicable, even if you could take them apart would you want to risk it not going back together properly?
If its jamming you could try a touch of crc but thats all I would do.
Hi Im Ben, Have a nice day :)
DVSMOTORSPORT
Postby ollieboy » Fri Jun 22, 2012 1:47 pm
Yeah I couldn't be bothered in the end anyway so just bought a new one.
ollieboy
Users browsing this forum: Google [Bot] and 30 guests
