Urgent Help!
Urgent Help!
Postby bzrspeed » Thu Jun 28, 2012 4:32 pm
I am working on BT50 3.0D turbo and replaced rear main seal but still leaking, replaced again with new part and still leaking.
Ideas?? I have installed correctly and part is factory new so what else could it be?
Help this has me very confused.
bzrspeed
Postby Burning Angel » Thu Jun 28, 2012 4:48 pm
excessive crankcase pressure causing oil to blow past the seal?
damaged sealing surface on the crankshaft?
thats all I can think of really
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby bzrspeed » Thu Jun 28, 2012 4:53 pm
I have run the engine with the rocker cover cap off which should relive the pressure. Very good idea. thank you
But still did not work.
bzrspeed
Postby hsmidy » Thu Jun 28, 2012 5:17 pm
the seal sureface on the crank maybe too worn, you can get what they call a speedie sleeve to slide over it to give it a new sealing surface,
this is more likely with High km's vehicles
hsmidy
Postby Mr Revhead » Thu Jun 28, 2012 8:50 pm
Double lip seal easier option
Postby evil_si » Thu Jun 28, 2012 9:02 pm
How are you installing?
Seal housing cracked?
evil_si
Re: Urgent Help!
Postby allencr » Sat Jun 30, 2012 12:13 am
bzrspeed wrote: I have installed correctly and part is factory new so what else could it be?
Nothing.
"installed correctly'" is the major cause/source of forum problems!!!
allencr
Re: Urgent Help!
Postby Crucible » Sat Jun 30, 2012 2:40 am
Nothing.
haha so true. Most of the hyped up BS I read on forums doesnt happen in the real world.
Its like working with apprentices, they talk the talk but put em on the floor they know sweet $&#$% all.
Experiance is the differance.
Crucible
Real Life Mechanic
Postby rollaholic » Sat Jun 30, 2012 1:57 pm
are you sure its the seal thats leaking?
housing gasket?
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
