Show us your sump!
Show us your sump!
Postby cat007 » Sat Jun 30, 2012 11:37 am
Just interested in what sort of sumps you're all running - transverse engine or longitudinal engine.
I do like the idea of making a sump that holds a decent amount of oil and will help prevent surging.
Postby nz_climber » Sat Jun 30, 2012 12:05 pm
Dry Sump!
3sge beams longitudinal engine
Holds no oil.. but prevents surging
Probably not to helpful, but gives you another option.
nz_climber
Postby 92mr2paddy » Sat Jun 30, 2012 1:55 pm
not "toyspeed" related but i have a winged and baffeled with hinges morosso sump on my s14 drift car and dave at d-tech fitted a pressure sensor switch that limits power at certain oil pressure and at low pressure motor shuts off to prevent oil starvation,
sensor bout $350 plus a tune map on the link, would benefit anyone that goes racing/hill climb whatever your into,
my 2c :)
92mr2paddy
Postby rollaholic » Sat Jun 30, 2012 1:56 pm
pics worth posting anyway imo.
looks nice!
Postby Mr Ree » Sat Jun 30, 2012 3:07 pm
Beautiful dry sump, very jealous.
Luckily the jza80 has a very well designed "rear" sump from the factory, with large capacity, and a windage tray of sorts. I have tracked my car alot, and have an oil pressure gauge to keep an eye on things, but even running full slicks, Im yet to notice a drop off in OP through long constant radius turns.
With that said, if I ever have to remove my engine in the future, I will without a shadow of a doubt get a proper baffle system and complete windage tray installed to make my setup even safer.
wak thud gush!
Mr Ree
Postby Celica RA45 » Sat Jun 30, 2012 4:00 pm
i run a wet sump 3sge motor ,the only things that i have done is drop the oil pick up 5 mm further down with 1 gasket alloy spacer and another gasket
on the steel pan just block off around the pan and put a 26 mm extension on the dip stick hole .works well and im pulling 1.8 g through corners with wet sump
Celica RA45
