1I1 wrote:I enquired about getting an exhaust cert a couple of years ago but didn't bother going through with it. From memory was around $150
BZG|Bling wrote:If the spacers are specified on cert plate they are legal. if they aren't they aren't legal, pretty simple.
cat007 wrote:1I1 wrote:I enquired about getting an exhaust cert a couple of years ago but didn't bother going through with it. From memory was around $150
Sweet - well I might as well do that then - if it's the same price as the ticket then it would seem a bit silly to not get it done. As long as it's under the 90db limit haha
Has anyone got a db meter I could borrow to see if I'll pass before forking out $150?
Quint wrote:I've got a db meter, but doubt you want to go the distance.the reason he pulled me over was because he noticed I was using a spacer for my wheels (20mm spacer).
what a hawk eyed mofo.
cat007 wrote:strx7 why do you ask about the cage and motorsport card?
strx7 wrote:cat007 wrote:strx7 why do you ask about the cage and motorsport card?
cause if you have an authority card the exhaust noise "similar to factory" law goes out the window
Users browsing this forum: Bing [Bot] and 13 guests
