sergei wrote:All this data is from castrol site:
- Code: Select all
SAE Rating KV@40'C KV@100'C
25W-50 207 21
10W-60 174 23.5
15W-40 112 14.8
10W-40 98.8 14.5
5W-40 88 14.44
0W-40 77.5 13.1
KV is basically viscosity.
looking at the table 0w40 looks very good for normal driving, and this is the one I would suggest using (if $$$ allows).
jbod wrote:Ive used castrol magnetic 10w-40 in all 4 3sgte's I have had and they run like clockwork with it. Done alot of ks on them to with no deterioration of engine condition, seems to be a really good oil
Makaveli wrote:0WXX rated oils are designed for very cold environments. Countries like Canada, Russia etc. Thinner oil makes it easier for engine to start.
I think with turbocharged engine, the oil get's hotter than it would normally in a naturally aspirated engine as oil passes the turbine that spins at around 200,000 - 250,000 rpm.
Hence why you would need thicker oil.
Makaveli wrote:I think with turbocharged engine, the oil get's hotter than it would normally in a naturally aspirated engine as oil passes the turbine that spins at around 200,000 - 250,000 rpm.
sergei wrote:
you cannot simply get too thin with first number before W in the rating.
0W40 is still better than 15W40 even in hot environments, as you can see from my chart the viscosity at 40'C is almost ten fold of what it is at 100'C.
Why pay extra for a 0W when there is no benefit in using it? If you live in auckland and don't go to the snow there is no benefit in using a 0W if the manufacturere recommends a 10W, 10W is thin enough for the engine to turn over freely and flows fast enough.
