Heater not heating...
Postby doin donuts » Tue Jul 10, 2012 8:58 pm
Hey all, the wife's fielder Z's heater just doesn't seem to get warm, even after an hour of driving. Is there an obvious solution/fix? Or common problem?
Thanks all
Doug
4agze ae86 trueno...let the fun begin!!
doin donuts
Postby ollieboy » Tue Jul 10, 2012 9:13 pm
Does temp gauge go up to temperature?
Could be thermostat stuck open. Or blocked heater core but I don't imagine so on such a new car, but you never know.
ollieboy
Postby wde_bdy » Tue Jul 10, 2012 9:40 pm
Heater tap actually working? Check hoses in and out of heater core.
Callum
wde_bdy
Postby 85AW20v » Tue Jul 10, 2012 11:20 pm
Or the flap that lets air through the heater core is stuck shut.
See ya
Simon
85 MR2 20v
85AW20v
Postby doin donuts » Wed Jul 11, 2012 12:08 am
Temp gauge works fine,doesn't matter what mode it's in wether it's dash vents or windscreen it doesn't get warm. How do I check the core excuse the ignorance?
Thanks for the help
doin donuts
Postby cat007 » Wed Jul 11, 2012 12:20 pm
Check to make sure that when you put the heater from cold to hot and vice versa, the little vacuum operated valve that allows the hot engine water into the heater, is working.
That is of course that modern cars still operate like this?
Postby limbo » Wed Jul 11, 2012 2:06 pm
If the heater core is blocked wait for summer and sell the car.
I changed my heater core and its the worst job I have ever done on a car, you have to remove the whole dash and all heating ducts etc. core cost $50 or so to fix so its not expensive but its just hell and then when it all went back together it didnt seal up quite right so I have to re do the whole thing
limbo
Postby allencr » Wed Jul 11, 2012 5:07 pm
Heater core will have an inlet & outlet going through the firewall, inlet coming from the head with a valve to control the flow.
Feel that hose on both sides of the valve to know that it's getting hot & that there's flow through the valve.
Feel the outlet to know whether there is flow through the heater core.
allencr
Postby rollaholic » Wed Jul 11, 2012 7:01 pm
i cant say for certain but i dont think it'll have a valve. if both the hoses are hot, and there is coolant in the engine then you probably have an issue inside the heater box with the main flap like someone mentioned already.
Postby d1 mule » Wed Jul 11, 2012 8:23 pm
MAGN1T says BHG
d1 mule
Postby rollaholic » Wed Jul 11, 2012 8:26 pm
s'funny, even though he doesnt post here anymore, his opinion still gets voiced
Postby matt dunn » Wed Jul 11, 2012 8:42 pm
d1 mule wrote:MAGN1T says BHG
yep,
has to be a blown heater gasket, lol.
IMO it will be the stepper motor that works the flap,
will be external to the actual heater box, probably accessible from one of the footwells.
If it wasn't so dark and cold outside
or my garage wasn't full of broken racear,
I would have a look at mt fielder Z to see what they have.
Postby doin donuts » Wed Jul 11, 2012 9:34 pm
Ok guys,thanks for help,il see what I come across...kinda Sucks cause we have a baby so want the car warm for him and my 4 year old daughter
doin donuts
Postby gt4dude » Wed Jul 11, 2012 11:11 pm
flush the heater core
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
