d1 mule wrote:there is 0 point doing this conversion without at the very least some sort of fuel controller. For the money get a Link Atom.
d1 mule wrote:that being said running standard comp ratio is far less than ideal...
Dell'Orto wrote:Without a decent ECU, you'll blow it to bits in no time. There was a chap on here a few years back who did turbo an internally stock silvertop, TD04 and Link from memory and made 130kw on 5 or 6psi.
I dont know if the blacktop ECU will even run with positive pressure
98 Celica SR (ST)
315CC Sup Injectors
FPR
small FMIC
Walbro pump
Garrett T25 Turbo
2.5 inch exhaust system
Stage 3 clutch
First dyno with MBC and SAFC 2
Second Dyno with Greddy ProfecB Spec 2 and AEM FIC (no timing adjustment)
Soon Ford 440CC injectors and bigger FMIC. Timing now adjusted but no dyno yet.
dnalunchie wrote:Isn't turboing stock black top rods about as sensible as raising the boost on a gtt with a boost tap?
jacobrjett wrote: I am running silvertop conrods
jacobrjett wrote:yea im just gonna wait until my next car before i look at boost now
this only my 2nd car so i suppose its not too bad i dont have a boost yet haha
Users browsing this forum: No registered users and 26 guests
