T-50 gurus please reply
Postby fangsport » Mon Jul 16, 2012 10:27 pm
ok, in a mad rush to try and get my fix..............Joe might have Fooked up.
genuine worst case scenario replies only please.
i may or may not have installed a 22spline T40 without the thrust spacer between input shaft bearing and thrust bearing snout.
the old box (roller bearing) still has his one, but i don't remember one on the replacement box (ball bearing).
car only has to do 60-70km.
3T on 40's (130-ish HP)
4.8:1 welded diff
on gravel, apart from a quick squirt up the road to make sure it selects all gears.
fangsport
Postby l1ttle_d3vil » Mon Jul 16, 2012 11:37 pm
not sure on T40's, but I know it was only one of the T50's which had the spacer - may have been the 22 spline model.
As for running it without the spacer, I managed to get about 500km out of my box before the movement on the input shaft ended up chewing one of the synchros (IIRC) out... ended up not being able to select gears. Towed the car home and pulled the box out, ended up rebuilding it as it had metal shavings through all the oil... spun a spacer up on the lathe before I reinstalled it and it was fine ever since.
Postby fangsport » Mon Jul 16, 2012 11:45 pm
l1ttle_d3vil wrote:not sure on T40's, but I know it was only one of the T50's which had the spacer - may have been the 22 spline model.
but was the spacer only fitted to the roller bearing version and not the ball bearing ??
fangsport
Postby QikStarlie » Tue Jul 17, 2012 12:00 am
i have a 22spine t40 in bits here. with the ball bearing style bearing. can do some measuring if thats any help. should be an offset or width difference, if it doesn't require the spacer... cant remember if it had the spacer or not when i pulled it apart
QikStarlie
Postby fangsport » Tue Jul 17, 2012 12:08 am
QikStarlie wrote:i have a 22spine t40 in bits here. with the ball bearing style bearing. can do some measuring if thats any help. should be an offset or width difference, if it doesn't require the spacer... cant remember if it had the spacer or not when i pulled it apart
it is the ball bearing type i fitted yeasterday. i have the roller bearing box on my bench, so can measure how much it protrudes from the face of the housing.
fangsport
Postby fangsport » Tue Jul 17, 2012 12:10 am
P.S.
kinda urgent to know exactly if i NEED to pull it back out, as supposed to be in Rangiora Saturday nite/first thing Sunday.
fangsport
Postby QikStarlie » Tue Jul 17, 2012 6:53 pm
bearing race width - 16mm
with the input shaft sitting in case, bearing race protrudes 5mm
QikStarlie
Postby fangsport » Tue Jul 17, 2012 9:06 pm
QikStarlie wrote:bearing race width - 16mm
cheers man. had a good ol' chat with Sheldon Rush today and he thoroughly recommended removing box and making sure the was a spacer installed.
45mins had it on the bench, bell housing off............. including 10 mins cleaning gear oil off ratchet after i dropped whilst still draining.
FYI, did you know that gear oil slows a ratchet down quite considerably.
fangsport
Postby QikStarlie » Tue Jul 17, 2012 9:39 pm
so what was the verdict? did it need the spacer in the end?
nice, wish it took only 45min, to take the t50 out of my starlet.. is engine out job.
QikStarlie
Postby fangsport » Tue Jul 17, 2012 9:56 pm
appearently, yes. the forward thrust on the imput shaft "could" cause catasthrophic failure.
but then the lucky dip box could also fly to bits one the start line of the first run, but trying to reduce the risks
fangsport
Postby fangsport » Tue Jul 17, 2012 11:28 pm
done. and yes, the input shaft had moved forward a few MM in the 15M it traveled
fangsport
