KE25 Wiring Diagram or Photo
Postby 2LTR Rona » Wed Jul 25, 2012 11:34 am
Anyone have a wiring diagram (photo would be much easier) for a KE25, showing the ignition / steering column wiring?
In my haste to remove to loom a wee while ago I forgot to document / photograph it :oops:
/edit : should also say its running a bluetop 4A
Blair
2002 Altezza, 1974 KE25
2LTR Rona
Postby Dell'Orto » Wed Jul 25, 2012 4:06 pm
Pretty sure I have a KE2* workshop manual at home, will have a looked
Postby 2LTR Rona » Wed Jul 25, 2012 4:21 pm
Cheers for that !!!!
2LTR Rona
Postby l1ttle_d3vil » Wed Jul 25, 2012 9:43 pm
What are you wanting to know exactly? How its routed, or what wires are what etc?
Postby 2LTR Rona » Thu Jul 26, 2012 10:11 am
l1ttle_d3vil wrote:What are you wanting to know exactly? How its routed, or what wires are what etc?
What wires are what / what wires connect to what (on the back of the ignition barrel.
Short version, I had to remove the interior loom & as a result had to cut / disconnect two wires (now have four ends) one is solid green the other green with yellow stripe.
Due to the length time ago i did this, I now can not for the life of me remember which joined what or where, hence if someone had a 25 or similar & took a pic of the back half of ignition barrel showing how its connected i will have a starting point / will probably jog my memory
2LTR Rona
Postby l1ttle_d3vil » Thu Jul 26, 2012 9:28 pm
pretty sure I have an ignition backing sitting in my shed, and will be in wellington this weekend... can either take photos or bring it down with me if you want. Will be in the upper hutt area. from saturday morning until sunday afternoon.
Postby 2LTR Rona » Thu Jul 26, 2012 10:35 pm
If you could take a photo or two that would be ideal !!!! :-) i can then print out & take with me (KE is a wee way away from where i live)
Blair
2LTR Rona
Postby l1ttle_d3vil » Thu Jul 26, 2012 11:03 pm
No worries - I meant I can bring it down with me if you wanted it... its just sitting in my shed doing nothing, otherwise I can take some photos.
Will have a look for it tomorrow.
Users browsing this forum: Google [Bot] and 41 guests
