neelside wrote:hey
just tried resetting the ecu and no change, and the check engine light doesnt come on either.
sergei wrote:jacobrjett wrote:my first bet would be pull negative battery terminal for half an hour to reset the ecu
Pull the EFI Fuse for 10seconds instead, no reset clock or stereo...
jacobrjett wrote:fuel injection fuse resets ECU?
I did not know that.
matt dunn wrote:jacobrjett wrote:fuel injection fuse resets ECU?
No it does not.
Sergi is incorrect,
the Fuel Inj fuse is the ignition switched feed.
You actually need to pull the brake light fuse to do it as that is where Toyota ECU's battery supply comes from.
The ECU stores the code(s) until it is cleared by removing EFI fuse with ignition switch OFF
matt dunn wrote:No it does not.
Sergi is incorrect,
matt dunn wrote:Just recheecked, AE111 is batt feed through the IGN fuse,
so you were correct.
but the early suff the BATT is definatly through the Brake fuse.
like here on the Smallport 4AGE.
http://i16.photobucket.com/albums/b20/M ... -Feeds.jpg
