Lloyd wrote:http://www.dba.com.au/catalogue/download-pdf-catalogue/
Scroll down past the listings for vehicles and it'll give you all the dimensions for all the DBA rotors. Possibly easier than going exact dimensions if you have a little bit of sizing you can play with.
DeeCee wrote:I believed you have a Supra/Altezza/IS200 disc, 296x32mm, redrilled to 5x100. Not sure if you have hubcentric rings or not. Measure the centre bore, thickness and diameter of the old disc.
If your disc diameter is larger then you'll have to re-space the caliper out which is a major hassle.
UK guys grind a couple of mm off the caliper lug mounting points to remove need for spacer with altezza disc.
Shrike wrote:I thought st205 calipers and discs bolt straight up :s
St205 discs are 315 by 32mm and I know barry can get them
1I1 wrote:Sorry to hijack your thread Tyler
Anyone stumbled across a direct relpacement rotor when doing a twin pot conversion on a AE101 or AE111? to save having to machine SS rotors down.
RomanV wrote:About you not being able to cert with two spacers, is that a spacer for the disc and spacer for the caliper?
Not allowed both?
Or did you have two spacers for the disk itself somehow...
