Scottie wrote:Also, think about how you are going to get the oil back in. A suction gun may help.
evil_si wrote:Undo the plug underneath, 24mm socket from memory,
Drain oil
Refit plug
Undo same size plug on side of box,
Fill with oil untill its jus coming out of the fill hole
Replace the plug
I prefer to replace the copper / aluminium sealing washers at the same time
Mike- wrote:undo the filler plug first, just to make sure you can do it with the tools you have. cant drive it to the shop without oil
thegreatestben wrote:It's lucky you arent a douchebag other wise I wouldn't help you
