7afe blocks
7afe blocks
Postby Shrike » Fri Sep 07, 2012 10:43 am
I did a quick search both on here and google
Didnt really tell me much
Thought I would make a thread seeing as a few 7a/9a builds may be coming up :p
Just wanting to know if theres any differences between the different generation 7afe blocks
Shrike
Postby Bazda » Fri Sep 07, 2012 10:53 am
No difference :)
Postby matt dunn » Fri Sep 07, 2012 10:57 pm
some are multi coil and have a crank angle sensor in the oil pump,
so are dist and do not,
You dont use the oil pump anyway, so dont worry about that,
and have never struck a difference between any of the actual blocks I have had.
Postby Flannelman » Thu Sep 13, 2012 10:12 pm
Piggy back question, are 7a/9a blocks dimensionaly the same in crank location as a 4age block?
As, Im designing a crank gurdle for the 4age. It would be nice if this could be used on these blocks as well
Flannelman
formerly known as Affroman
Postby Bazda » Thu Sep 13, 2012 10:30 pm
Flannelman wrote:Piggy back question, are 7a/9a blocks dimensionaly the same in crank location as a 4age block?
You mean 4a block same as 7a block.
No such thing as a 9a block.
Yes they are the same. If your doing a crank girdle it needs to attach to all the sump bolts make it a really good design!
Postby Flannelman » Fri Sep 14, 2012 9:49 pm
Yea, was looking at a waterjet cut 12mm-15mm thick plate that sat around the base of the block with ribs running over the main caps. The sump would have to be shortened by the same amount to keep it at stock height. New holes would have to be drilled and tapped so the gurlde is fastened to the sides of the block
The headache is that the caps sit 10.5mm below the sides of the block. Going to a longer stud is nessasary but trying to fasten the cap is proving difficult.
Flannelman
Users browsing this forum: No registered users and 37 guests
