dnalunchie wrote:depends if you want it down cheap or down right. Cheap, any old performance garage. Right. ST hitec. Best shop in auckland probably.
loudstealthGT-Four wrote:How much power are you hoping to make after turboing it?
Would be easier and cheaper to just pick up a Gen3 3SGTE from a SW20 and go from there.
Al wrote:dnalunchie wrote:depends if you want it down cheap or down right. Cheap, any old performance garage. Right. ST hitec. Best shop in auckland probably.
The shop that tells you what you want to hear for the price you can afford generally becomes more expensive than the expensive shop once you factor in your car still sitting in bits in their workshop 6 months later and makes barely more power than your old bolt on setup.
Al wrote:Have you read Mandalay's thread on MR2OC.com regarding his redtop beams with rotrex supercharger ?
Good (and huge) read, he doesn't do things by halves.
http://www.mr2oc.com/showthread.php?t=323444
RomanV wrote:The EHPS runs completely independant to the engine ECU, if I recall.
I dont think it even references the speedo signal, as I've driven around with a broken speedo cable and had no PS issues.
