5.5 Batteries: Are defined as either ‘dry cell’ or ‘wet cell’ and shall comply with the following:
(1) For all batteries the live terminal shall be adequately insulated, and
(2) For Series Production vehicles:
(a) Where the battery remains in the original position, the original fixations may be
retained, or
(b) Where the battery is moved (from the original location):
(i) It shall be mounted on a flat metal base, and
(ii) Be secured to the bodyshell using at least two(2) insulated metal straps
and four(4) bolts of minimum specification of ISO 8.8 M6.
(3) Specifically for ‘wet cell’ batteries relocated in the cockpit the following applies:
(a) The battery shall be secured as per Part One Article 5.5(2)(b), and
(b) Shall be contained in a leak-proof box that is vented to the vehicle exterior.
TTEETT wrote:Club Membership.
Clubsport Licence.
Fire Extinguisher with two straps mounted properly to the floor, you can find info online but you need correct bolts and washers etc . Would suck to turn up to an event and not be able to race.
I would invest in a basic race suit, gloves, boots and a quality helmet, possibly a neck brace because when you crash and catch on fire it can be painful.
This should clean you out for a while but is where you should spend the money first.
Leon wrote:I think I've got at least four complete sets of wheels and tyres for the Corolla at the moment.
TTEETT wrote:Hydraulic handbrakes are nice, but I would say not something you need to spend money on initially, I do lots of gymkhana/graskhana/gravel events with various car clubs at clubsport level and most of the time the winning cars don't even have them! Most of all you need the skills, the toys come after when you develop the skills.
strx7 wrote:The 2013 Clubsport Champs are in tauranga next March, come for a play.....
Leon wrote:strx7 wrote:The 2013 Clubsport Champs are in tauranga next March, come for a play.....
Maybe start a new thread some place about that event ... cos depending on the composition of surfaces being used etc, you'll get possibly 8-12 guys and girls from HCCC (several of which are Toyspeeders) missioning up to that one.
Users browsing this forum: No registered users and 36 guests
