matt dunn wrote:interestingly they say with a 5 litre v8 but dont mention what brand the engine was. hmmmmm.......
Lloyd wrote:"The Mercedes touring cars will be powered by a modified version of the 5.0-litre V8 currently used in the SLS AMG GT3 race cars."
Apparently
2jayzgte wrote:I even saw the Kellys had there new Allloy V8 on the bench next to there GM counterpart and apparently there chalk and cheese the Kelly's thought the Nissan unit looked like something out of F-1 and was about 30 odd kg lighter also vs the cast iron good ole boy from the US.
Mr Revhead wrote:Lloyd wrote:"The Mercedes touring cars will be powered by a modified version of the 5.0-litre V8 currently used in the SLS AMG GT3 race cars."
Apparently
Yeah this has been stated in several releases. Except its the SLS engine sleeved down to 5L
Truenotch wrote:2jayzgte wrote:I even saw the Kellys had there new Allloy V8 on the bench next to there GM counterpart and apparently there chalk and cheese the Kelly's thought the Nissan unit looked like something out of F-1 and was about 30 odd kg lighter also vs the cast iron good ole boy from the US.
Yeah, local speedway guys have been de-stroking the VK56 motor and have said that it's like a modern incarnation of a Ford DFV V8.
Mr Revhead wrote:Will be hard to as the intake set ups are trade secrets
fangsport wrote:Truenotch wrote:2jayzgte wrote:I even saw the Kellys had there new Allloy V8 on the bench next to there GM counterpart and apparently there chalk and cheese the Kelly's thought the Nissan unit looked like something out of F-1 and was about 30 odd kg lighter also vs the cast iron good ole boy from the US.
you sure it's the VK56 ?? plenty of stockcar guys have downsized the VH?44, but taking over 1.6l off the VK56 motor would take some doing, 200cc per pot !!
Truenotch wrote:
Yip, I'm sure. Brian Hartley is the one building them and they'll keep making power over 9000rpm. AFAIK they've had custom cranks made to de-stroke them. Not sure if they've done sleeves or not, but he's said that the heads are a work of art.
