Carbon Fibre! (where to buy a straight flat panel?)
Postby MrOizo » Mon Oct 01, 2012 10:51 pm
Currently weighing up whether to have the dash panel made from carbon fibre or maybe a carbon fibre vinyl (to at least see how it looks).
Anyone know of any places that can do a 700 x 150 x either 2/3/4mm panel, and know the costs?
Is 2mm thick enough to hold gauges like in this set up:
MrOizo
Toyspeed Legend
Postby matt dunn » Mon Oct 01, 2012 11:03 pm
photo doesn't show it too well, but mine is carbon fibre sticker over alloy panel,
are you looking for something like that?
Postby MrOizo » Mon Oct 01, 2012 11:06 pm
Looks good!
I have had a look on TM and come across some 3M stuff (guessing is very good quality) and some other generic stuff. Might buy either tomorrow if i can find some where i can eye ball first.
Where did you get yours Matt?
MrOizo
Toyspeed Legend
Postby matt dunn » Mon Oct 01, 2012 11:07 pm
The local signwriter that does a lot of race car stuff had it.
we have also used it on other bits and peices on the MRS etc.
Postby Grrrrrrr! » Tue Oct 02, 2012 12:09 am
I could make you a real carbon fibre panel if want Adrian.
2 layers of carbon either side of foam core. (2mm of solid carbon would be more than $200)
Will lay it up on glass so you get one good side and one rough side (good for gluing mounts and stuff to)
$80, and would be about two weeks before I get a chance to make it.
Let me know if you're keen.
Grrrrrrr!
Postby MrOizo » Tue Oct 02, 2012 10:06 am
Grrrrrrr! wrote:I could make you a real carbon fibre panel if want Adrian.
Sounds good! Would it be better to give you the panel and make it to the size i have cut (save wasting the off cuts if you know the size it needs to be?) Will it handle all the gauges in it not being 100% carbon? (I have no idea what it can support :P )
Stott69 wrote:Ive just done a few trim peices in the car with the cheap stuff off trademe. Easy enough to do yourself, just make sure you have a clean work space.
matt dunn wrote:The local signwriter that does a lot of race car stuff had it.
I will go for this if i fail with the real CF. Cheers guys!
MrOizo
Toyspeed Legend
Postby 1I1 » Tue Oct 02, 2012 10:22 am
Adrian you could always have a piece of thin alloy etc in behind the CF for strength if you are worried? I did that with my gauge cluster (made small brackets flush behind the CF to add support)
TRD Clicky >>Here
1I1
Postby Stott69 » Tue Oct 02, 2012 10:39 am
Stott69
Postby Akane » Tue Oct 02, 2012 7:52 pm
Chop strand fibreglass behind the carbon fibre for strength IMO. And bag it if you really wanna go the extra mile.
Postby Grrrrrrr! » Tue Oct 02, 2012 8:36 pm
Should be fine with foam core, but i can throw a couple of layers of glass behind the carbon if you want. (glass is cheap)
I'll keep it rectangular, its just easier for me.
Grrrrrrr!
Postby MrOizo » Thu Oct 04, 2012 9:44 am
Grrrrrrr! wrote:Should be fine with foam core, but i can throw a couple of layers of glass behind the carbon if you want. (glass is cheap)
All gravy - Glass is good.. Whats the best way to get this underway?
It measures 700x140 but i think 700x300 would be best so i can do a second one in case i stuff it up :)
I think 2-3mm think around the edges would be good.
Doyou want me PM you or you PM me with finer details?
Cheers!
MrOizo
Toyspeed Legend
Postby Grrrrrrr! » Thu Oct 04, 2012 3:33 pm
No worries, i'll start grabbing the materials I need as i get time. Just sorta stupidly busy with work atm so making time during the working week is a challenge.
If anybody has a piece of glass about 1100 x 600 that they're willing to donate that'd save me from buying one:)
Grrrrrrr!
Postby Shrike » Thu Oct 04, 2012 4:36 pm
ive got lik 40m or so of 300gsm fibreglass matting 1m wide if you need some
Shrike
Postby GDII » Thu Oct 04, 2012 5:10 pm
I think he means clear window glass. So he can use the flat surface as a mold for the carbon fibre.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Grrrrrrr! » Thu Oct 04, 2012 6:23 pm
GDII wrote:I think he means clear window glass. So he can use the flat surface as a mold for the carbon fibre.
Bingo.
Grrrrrrr!
Postby Grrrrrrr! » Sat Oct 13, 2012 5:25 pm
Flat plate on glass, excess resin bleeding into the breather.
Should get it to you middle of the week Adrian.[/img]
Grrrrrrr!
Postby MrOizo » Sat Oct 13, 2012 8:06 pm
Wow you are a legend! Thanks :)
MrOizo
Toyspeed Legend
Postby Grrrrrrr! » Tue Oct 16, 2012 12:08 am
Finish isn't as good as photo implies, there are a few pinholes and a few defects (most near the edges luckily) that Adrian will have to work around. Next flat panel i make will be done a different way for better result.
Pm me your number adrian, and i'll drop it round after work tomorrow evening (likely after 7ish).
Grrrrrrr!
Postby MrOizo » Tue Oct 16, 2012 12:11 am
Oh my gosh! Very nice.
PM-ing now :)
MrOizo
Toyspeed Legend
Postby blindnz » Tue Oct 16, 2012 8:01 pm
was this vacuum infusion? I've looked at doing some of this myself looks legit.
iOnic wrote:Don't take me too seriously - I own an MR2.
blindnz
Users browsing this forum: No registered users and 42 guests
