bzrspeed wrote:Hi...
A little stuck, have 18 bolts to remove, all have a hex head of between 1.5inch and 2inch and are about 5 to 8 inchs long.
Adoom wrote:bzrspeed wrote:Hi...
WOW! Those bolts are HUUUGE!!![]()
Can you use a REALLY long lever? Like 2 metres long...
I once had to use a propshaft with a 1" socket welded to it as the mother of all breaker bars to undo some epic tight hub nuts.
With bolts that big, I wouldn't think you could break them?
bzrspeed wrote:the steel is 500 bdu strength, heat treated, so an oxy would not even heat the steel around the bolts. also the piece weighs close to 1 ton so it also has pressure on them. Have a forkey hooked up to hold it.
Got a good size breaker bar, tried the rocking way but still wont budge. Dont want to drill them as it would be an ass to replace.
Not having a good weekend. Needed this off by thursday. Boss aint going to be happy.
