Shrike wrote:Checked your spark plugs? could be the wrong heat range and when it gets hot they preignite?
Also a boost gauge would be a good idea just to confirm it is running factory boost
Lloyd wrote:So.... if its working fine at the moment then how is it a fuel pump issues????
allencr wrote:Pre-ignition is not detonation and does not ping.
Here's a better link, one on both Detonation and Pre-Ignition
http://www.contactmagazine.com/Issue54/ ... asics.html
FSRRM wrote:I found this near where you said which ones do I cross? ]
FSRRM wrote:So I took out my fuel pump relay and put a spade over the pins to bypass this
It seems to boost hard more often than it used to so im thinking it's the fuel pump
Cant wait to get the pump and fit it when it arrives ^_^ ]
LEAKER wrote:Wow didn't see that coming! Thats a really wiered thing to have happen. Is yours a usdm spec one? I know youre not supposed to but i used to run mine on gull force 10 when i lived in auckland and it loved it. Used to run so much better! I wonder if yours may have a had the compression raised at all at some point? Maybe just a head skim taken slightly too far....
DeeCee wrote:what internal bov? st185 A2A didn't come with a bov/dump valve. Unless you are making noises in the cabin when you drive.
FSRRM wrote:DeeCee wrote:what internal bov? st185 A2A didn't come with a bov/dump valve. Unless you are making noises in the cabin when you drive.
Weird :-S thanks for the info! Well when I accelerate I hear a jet engine noise and then I take my foot off the pedal it makes a loud psh sound?
#NewToTurbo
Thats just turbo chatter/flutter, caused by the air pressure built up in your intercooler, as the throttle closes and the air has no where to go, but back through the turbo.
It is alot more audible with an aftermarket pod filter, the factory airbox is designed to quieten the intake noises
loudstealthGT-Four wrote:Most people just weld the BOV adapter onto the bit of piping between the turbo and intercooler, just need to do abit of research with what BOV you are going to run if you want to vent to atmosphere as some will cause the car to run abit rough as they muck up the AFM.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 34 guests
