Lloyd wrote:Split conduit stuff is probably easiest, and you only really have to tape it at the ends, if at all. Super easy to put on, flexible, prevent wires rubbing on stuff and reasonably resistant to heat.
Dell'Orto wrote:I use Hamal vinyl loom tape, its quite stretchy so you can pull it tight to keep everything bound together.
Adoom wrote:Dell'Orto wrote:I use Hamal vinyl loom tape, its quite stretchy so you can pull it tight to keep everything bound together.
I think the white tape I have is hamal.,,,, but it's white![]()
Do Repco stock it?
I'm not sure that split conduit would suit my loom. The loom is quite short, and has wire off-shoots all along it. The only long run is just two wires thick.
