i didn't think titanium, being a metal alloy, had much thermal insulating properties??Mr Ree wrote:Coryn and I bought some titanium backing plates last year, which helped slighty, but still, critical mass is eventually reached.
2jayzgte wrote:Ducting is also vented to the centre of the rotor aswell.
allencr wrote:Still have those anti-rattle shim between the pad & piston? If so, throw them away, they're just causing the pad to release less & drag more. It's not by much but you sure don't need any more.
2jayzgte wrote:Branden you could be onto something there heat soak I also think is a problem and your solution to allow the heat to escape off the back of the backing plate is also a feasible idea.
2jayzgte wrote:He explained once he has deleted the ABS the brake bias will be 50/50 front to back and will install the valve and dial off the back brake accordingly to you feel just a little bit of squirm in the back of the car he thinks thats about optimal.
