AE92 highpressure PS line: new or make one?
Postby ~SlideWays~ » Tue Oct 16, 2012 10:52 am
My AE92 GTZ is running a 4age PS pump on a custom made bracket, it was years ago that I fitted it. I've just taken the engine out and noticed that the high pressure line is starting to perish and crack.
It was so long ago that my memory is a bit vague, but I'm pretty sure I had to use a high pressure line from a 4age 16v to match the PS pump. Its not a prefect fit because the solid parts of the line don't quite fit (extra bends on the steering rack end).
Just putting it out there, would I be better off getting ENZED to make up something (are the threads unique?) or just try get a matching TGP new one? The reason I ask is because the only thing I've had made by ENZED was a turbo oil feed line and that was pretty pricey so I'm unsure if it would be economical vs's getting a new TGP (if they are available).
Would push lock fitting work?
...I'm not a cheap arse, I just have many many expensive things coming up or on the go! :lol: e.g. an engine rebuild (unexpected), my wedding, major house renovations, trailer build, a bit of panel beating etc etc.
~SlideWays~
Postby matt dunn » Tue Oct 16, 2012 7:14 pm
I made up a PS pipe with Air con fittings and our hydraulic crimper we use for crimping the ends on, worked fine,
but I dont know if pushlock would hold the pressure on full lock?
Postby Bazda » Sat Oct 20, 2012 2:51 pm
Pushloc NO.
You need to Aeroquip screw together fittings designed for super high pressure. I got it on my car.
Its not the braided lines or fittings, these are different again.
Postby gt4dude » Sat Oct 20, 2012 3:56 pm
Isn't oem held in with hose and clamp? when it comes to the ps cooler?
and doesn't it go
reservoir -> pump -> cooler -> steering rack -> reservoir
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby Bazda » Sat Oct 20, 2012 4:36 pm
gt4dude wrote:Isn't oem held in with hose and clamp? when it comes to the ps cooler?
and doesn't it go
There is a high pressure line which is not hose clamped, uses special screw on fittings.
The feed line to the pump and return from the rack are hose clamped lines. But from pump to rack is the HP one.
Postby Mr Revhead » Sat Oct 20, 2012 7:41 pm
Cheapest, easiest and safest option would be hydraulics place. Shop around if enzed were too much.
Prob be 100ish. Depends if they have fittings that suit or have to weld the originals to the crimps
Postby Bazda » Sat Oct 20, 2012 11:07 pm
This is what I got:
http://www.alertmotorsport.com/Product/ ... +Hose/4200
With fittings it was approx $100.
Looks like this - Blue hose running along the eng mount:
Postby Mr Revhead » Sun Oct 21, 2012 9:18 am
Looks prettier than hydraulic hoses lol
How do the fittings attach to the hose?
Postby Bazda » Sun Oct 21, 2012 12:11 pm
Mr Revhead wrote:Looks prettier than hydraulic hoses lol
They are a screw together fitting.
So it squahses the hose onto the fitting as you screw it together.
The fittings are quite long so the hose has to be pushed over a long snout on the fitting first before the other part comes and screws over it.
Yes they are very tidy!
Postby Mr Revhead » Sun Oct 21, 2012 1:03 pm
Oh yep olive type.
Postby Mr Revhead » Sun Oct 21, 2012 1:04 pm
Oh yep olive type.
Postby Bazda » Sun Oct 21, 2012 1:54 pm
Mr Revhead wrote:Oh yep olive type.
No olives in this setup. But its similar to those fittings with a much longer and thicker snout.
Postby Mr Revhead » Sun Oct 21, 2012 2:17 pm
Like an olive without the olive! Lol
