Shrike wrote:Why do you have a silver top plenum??? one they wont hold boost and two they don't flow as well as a blacktop one (you can weld them up but I would suggest getting a custom one made ie from Barry)
What version link?
What gen gt4 injectors ? are they 440cc ?
T2 or t3 flange
550hp fuel pump?
It wont harm the engine as long as you run it in properly and tune it to suit
But it will be gutless compared to the factory blacktop :S
If you run the older 4agze pistons and a trd 0.8mm head gasket you will get roughly 8.5:1 comp or if you run the late model 4agze pistons (8.9:1) and a trd gasket youll get 9.5:1
What power goals are you after?
Ie a t28 from an s15 should be good for 180kwish atw at around 17psi and be fine running 9.5:1 comp assuming your charge temp and fueling is good
440cc injectors are good on a 4 cylinder to around 300hp at the engine
Can give more info once you answer
tsoob wrote:yup, think about this what are you going to be using the car for, and what supporting mods will you do?
Brakes, Suspension etc are just as important as your power setup.
KIPH8N wrote:Shrike wrote:Why do you have a silver top plenum??? one they wont hold boost and two they don't flow as well as a blacktop one (you can weld them up but I would suggest getting a custom one made ie from Barry)
What version link?
T2 or t3 flange
550hp fuel pump?
Well i had a silvertop before but then i upgraded to blacktop i know it wont fit so was thinking i would need a new plenum
Im after 300hp in the future.
The injectors are off the st185 gt4.
I have a 500hp fuel pump.
This is the link i have came with complete uncut loom. The old owner had it on his 4agte tuned on 15psi
http://s1128.beta.photobucket.com/user/ ... ort=3&o=74
Shrike wrote:KIPH8N wrote:Shrike wrote:Why do you have a silver top plenum??? one they wont hold boost and two they don't flow as well as a blacktop one (you can weld them up but I would suggest getting a custom one made ie from Barry)
What version link?
T2 or t3 flange
550hp fuel pump?
300hp at the wheels or at the fly?
Im paranoid but I would include a surge tank in your list
You would need to retune the link to suit your build
Also its an older link so you wont get all the features of a newer model but it would work ok
st185 are 430cc 7mgte and 2jzgte are 440cc
st205 are 540cc
440cc should be ok at 180kw
.:O4AGTZ:. wrote:If you already have that list of parts, why not get the final bits needed and turbo straight away? Will be a bit of a pig to drive NA with the lower compression. Might as well do the whole job at once!
jacobrjett wrote:Shrike wrote:Why do you have a silver top plenum??? one they wont hold boost and two they don't flow as well as a blacktop one (you can weld them up but I would suggest getting a custom one made ie from Barry)
I believe he means a sealed plenum designed for the silvertop (IE silvertop itbs are 42mm, blacktop are 45mm) i saw a picture of it its all welded up and wont leak.
I suggested he run 4agze pistons so he could turbo in the future, I really wouldnt think it would make it "gutless" though, sure it would lose a bit of power but with a fresh rebuild with fresh rings etc. he would still have good compression anyway, i figured with the TRD head gasket and 4agze pistons it would still be a quick motor. I mean what would it be like 9/1 compression ratio? thats still more compression then most N/A engines right?
then considering the amount of turbo parts he already has, it wouldnt be long before he has a turbo conversion. Wont be gutless at all then
The only thing I was wondering was if the factory tune for the high compression ratio engine may not be very good on a low compression engine. thats what im wondering.
sure it would lose a BIT of power though but I doubt it would be as sluggish as you suggest... although im not questioning your knowledge about this stuff
QikStarlie wrote:dropping the compression isn't going to make it run noticeably richer. nothing even close to bore wash level
dumping extra fuel after increasing compression isn't going to stop it detonating. amount of fuel doesn't have as much effect on detonation, as most people think, especially na. timing is what you will need to adjust.
dropping the compression to 9.5 isn't going to make it that lazy. sure it will loose a little bit , but will need to go alot lower than that to make a "pig"
agree its going backwards, but if its going to be turbo in a few months. why not?
Shrike wrote:
I was trying to point out that adding compression to the blacktop with a factory ecu is easier then dropping it
