92mr2paddy wrote:...couldnt spot anything obvious
2jayzgte wrote:Have a look on the engine build plate if its a AO2B diff this is the code for a Auto Torsen Diff.AO1B is the open diff code.
phoenix wrote:2jayzgte wrote:Have a look on the engine build plate if its a AO2B diff this is the code for a Auto Torsen Diff.AO1B is the open diff code.
01/02 denote different ratios don't they? From memory B is Torsen, A is open for Supras & Soarers (talking about the last letter)
92mr2paddy wrote:sweet will check that tomorrow,
ive only ever had a lsd diff fail in the way that it stops locking, but could the diff be causing the wobble? are there any arms in particular that casue this? maybe swaybar or something?
92mr2paddy wrote:tires are pretty bald
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
