Turbo Oil Feed Restrictor
Postby steroidcontaskie » Fri Oct 26, 2012 9:48 pm
Hi All
I was having a criuse of the Club na-t forums and some people there were saying you should have oil restrictor on the turbo oil feed for a journal bearing turbo.
Is this a good idea? They were saying that it will help the turbo spool faster and stop the turbo seals from leaking, but I always thought you didnt use a restrictor for journal bearing turbos.
I have a -4an feed and I get a bit over 80psi on cold start, turbo is journal bearing.
What do you guys think? Should I just leave it as is or put a restrictor in?
Edward
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
Postby Grrrrrrr! » Fri Oct 26, 2012 10:22 pm
Grrrrrrr!
Postby MrOizo » Fri Oct 26, 2012 10:30 pm
Have a talk to Alltech. They're your best bet.
I was told a restrictor was needed for t04z but they said not to worry. I would believe their word over any random on the net :P
MrOizo
Toyspeed Legend
Postby steroidcontaskie » Fri Oct 26, 2012 10:32 pm
Yea, that sounds like a good idea.
Cheers for the responses
Edward
RVR Turbo (idle)
steroidcontaskie
Postby evil_si » Sat Oct 27, 2012 8:13 am
Thats an excellent link
evil_si
Postby Mr Ree » Sat Oct 27, 2012 10:06 am
You definitely DO NOT need to run a restrictor on your turbo mate.
Whoever said is will help journal bearing snails spool better is very much the eternal optimist
wak thud gush!
Mr Ree
Postby steroidcontaskie » Sat Oct 27, 2012 7:12 pm
I get the feeling that some of the guys on club na-t are slightly muppetish. Toyspeed seems much better for considered advice.
Cheers again for the imput
RVR Turbo (idle)
steroidcontaskie
Postby MrOizo » Sat Oct 27, 2012 7:20 pm
steroidcontaskie wrote:I get the feeling that some of the guys on club na-t are slightly muppetish. Toyspeed seems much better for considered advice.
Maybe they have experience and even though they have done something dodgey, it's worked and is still working.
If something dodgey works thats all good! Still run it past some one in the know/industry :)
MrOizo
Toyspeed Legend
Postby Lloyd » Sat Oct 27, 2012 7:50 pm
Plenty of stuff works, the key is if it is going to last long though.
Postby mega4a » Sat Oct 27, 2012 9:24 pm
i had to run 0.8mm restrictor on my skyline turbo to stop oil leaking out the seal
mega4a
Postby Mr Ree » Sun Oct 28, 2012 9:14 am
mega4a wrote:i had to run 0.8mm restrictor on my skyline turbo to stop oil leaking out the seal
Was it a ball bearing or journal bearing?
And was the turbine housing oil seal worn?
wak thud gush!
Mr Ree
Postby loose_unit » Sun Oct 28, 2012 11:05 am
Have always run restrictors on the 4e/5e engines with larger turbos on them. Have had very good reliability with the Nissan based turbos.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Users browsing this forum: Bing [Bot], Google [Bot] and 21 guests
