....could also cause the flywheel bolts to stretch and loosen.crispy'86 wrote:I'm picking it'd act as a gearbox support much like the rwd t50's etc. just your gearbox wouldn't be properly botled up to the engine at the bottom which may affect the clutch operation, not to mention the bellhousing may get cracked with the stress (not being bolted all the way round and the force being unevenly distributed
Flannelman wrote:Major stall on this, just got off the phone to ARP. Im looking at close to $8-900US just for a single set of 10 studs made to lenght or $20-30US per stud on a run of hundred. This is only on the chance that some blanks can be found at the right lenght to save cost. This also doent include the nuts and washers!
So a quick tally up sees that for a run of 100, each set will cost on worst case of $40US each stud and 2 nuts and 2 washers. Add roughly 20% for US to NZ so thats $48... Times 10 = $480... Plus GST of 15%... gets a total of $552 each set. 10 sets to make 100 is $5520.
Thats not including postage or import duty...
Ouch, I hear my wallet crying from the car outside. Or is it me?
Users browsing this forum: Google [Bot] and 38 guests
