water pump o ring too small?
Postby Vertigo » Mon Nov 05, 2012 7:25 am
So I'm having a bitch of a time trying to fit the o-ring on the water pump if my 4agze. it seems just a bit too small, but its the correct part, I'm sure. any advice?
TVIS just kicked in, yo!
Vertigo
Postby sergei » Mon Nov 05, 2012 8:45 am
Is it the one that mates water pump to the block under cambelt?
Postby Vertigo » Mon Nov 05, 2012 6:32 pm
yeap thats the one. trying to stretch it just results in slippage.
(lol)
Vertigo
Postby Mr Revhead » Mon Nov 05, 2012 6:37 pm
Where did you get it from? Never come across one that I'd call a tight fit
Postby sergei » Mon Nov 05, 2012 7:10 pm
They normally fall out.. I think you have wrong one.
Postby Mr Revhead » Mon Nov 05, 2012 7:30 pm
sergei wrote:They normally fall out.. I think you have wrong one.
Yeah I remember the first one I ever did :evil:
Postby jacobrjett » Mon Nov 05, 2012 9:50 pm
you could boil it... but i wouldnt...
jacobrjett
Postby siren676 » Mon Nov 05, 2012 10:06 pm
When i did my starlets water pump it came with a smaller o ring which i had to use on the metal pipe which goes into the rear of the pump and i used gasket goo for the block seal
Maybe your engines the same?
siren676
Postby ee904age » Tue Nov 06, 2012 12:43 pm
I had the same problem a while back, think it was on my old SW20. Work your way around the o ring slightly stretching it between your fingers. Did the trick for me.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Vertigo » Tue Nov 06, 2012 1:40 pm
Ended up going to a seal shop...
.. and getting a bigger one - all good cheers!
Vertigo
Postby 85AW20v » Wed Nov 07, 2012 9:12 pm
Vertigo wrote:Ended up going to a seal shop...
It's easy to see what the problem was - that is a baby seal :D
See ya
Simon
85 MR2 20v
85AW20v
