Resonators do they reduce noise or change tone?
Postby Bazda » Mon Nov 12, 2012 10:57 am
Yep you needs 2x long resonators!
Postby gt4dude » Mon Nov 12, 2012 11:16 am
In my exhaust stream I used to have
Turbo (T28 housing) -> 3" mild steel -> 3" oval muffler -> 3" mild steel -> 3" oval muffler
the system was very quiet, had no loud barks, but the bass from idle was enough to shake down a house like christchurch,
then i changed to,
Turbo (T28 housing) -> 3" mild steel -> 2x Coby resonators -> 3" mild steel -> 3" oval muffler
now i have no bass tones, but the engine roars when its on song (aka 3500+rpm on boost)
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby ~SlideWays~ » Mon Nov 12, 2012 11:44 am
gt4dude wrote:In my exhaust stream I used to have
then i changed to,
Cheers for the feedback, what kind of oval muffler are you using?
~SlideWays~
Postby ~SlideWays~ » Mon Nov 12, 2012 11:46 am
Bazda wrote:Yep you needs 2x long resonators!
Chase type or AdrenanilR ones? I wonder if it will be enough if I get an 18" Chase resonator, I'm just not sure they are as well designed as the AdrenalinR ones.
~SlideWays~
Postby gt4dude » Mon Nov 12, 2012 12:31 pm
chase mufflers
the one i ditched was 3" offset in, 3" offset out
the one i retained at the rear is 3" centre in, 3" offset out
200AWKW / 370NM
gt4dude
Postby ~SlideWays~ » Mon Nov 12, 2012 12:46 pm
gt4dude wrote:chase mufflers
Cheers mate, it sounds like I might just need a big Chase resonator then.
~SlideWays~
Postby gt4dude » Mon Nov 12, 2012 12:52 pm
turbocharger and cat convertor quietens the obnoxious high bitch noise
resonator in turbo system seems to remove the bass tones (and possibly the high pitch ones on NA, though i wouldn't know)
oval mufflers seem to blanket the entire range of noises
200AWKW / 370NM
gt4dude
Postby Crucible » Tue Nov 13, 2012 10:25 pm
Yeah one resonator will never be enough and will make little differance.
At least two large resonators to take out that annoying cackly droan. Imo a better option than mufflers on a turbo vehicle.
Crucible
Real Life Mechanic
Users browsing this forum: Google [Bot] and 20 guests
