XYZ vs D 2
XYZ vs D 2
Postby FST4RD » Thu Nov 08, 2012 10:15 am
Looking at adjustables for my Starion race/road project.
I was looking at the D 2 gen2 stuff. I know a few guys running them in their Starions and they love them. However I have come across a company called XYZ doing them now as well. Never heard of them, anyone enlighten me? Better, worse, the same as the D2 stuff?
Custom isn't really an option. Mate went this way and it was quite expensive. Starions tend to be oddball when it comes to just about every part.
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby strx7 » Thu Nov 08, 2012 12:33 pm
XYZ is a good brand, especially if you go with their competition ones over the normal road ones (approx $2000 vs $1300)
in recent years XYZ brakes and suspension have been on the cars which have won a LOT of motor racing classes in NZ.
Postby iOnic » Thu Nov 08, 2012 12:46 pm
Lol @ D2 word filter :lol:
Postby FST4RD » Thu Nov 08, 2012 1:30 pm
strx7 wrote:XYZ is a good brand, especially if you go with their competition ones over the normal road ones (approx $2000 vs $1300)
Unfortunately the budget isn't going to stretch to the competition ones.
I paid $800 for the car, and right from when I got it I made a promise that it would be done on the cheap. So far so good, cost me bugger all, mainly adds and spirits!
I did say though that suspension and more importantly brakes I would do properly and not skimp too much.
I have read that the new D 2 stuff is far better then the original stuff?
FST4RD
Postby wde_bdy » Thu Nov 08, 2012 2:18 pm
Talk to Bazda
viewtopic.php?p=913971#913971
Did the setup for the front of my KP Starlet (had to be adapted to standard struts) at a very good price and looks pretty good quality.
Callum
wde_bdy
Postby FST4RD » Thu Nov 08, 2012 3:10 pm
wde_bdy wrote:Talk to Bazda
Callum
Thanks will do. Owned a couple starions and they are hard to get parts for.
LSD is proving hard. Either need a factory starion one, or one from a very very early 80s late 70s l200, l300, pajero etc. Not easy to find.
FST4RD
Postby touge_ae101 » Thu Nov 08, 2012 9:44 pm
The only reason xyz has been in a lot of fast racecars lately is speedfactor in tga rebuilds them to custom specs and sets them up like a bilstein. Just xyz body and shaft with custom valve. Not cheap xyz you get off tardme.
Save up for decent fortune auto shocks from bazda they will be waay better than cheap pos. You won't regret it.
touge_ae101
Postby FST4RD » Thu Nov 08, 2012 9:58 pm
touge_ae101 wrote:The only reason xyz has been in a lot of fast racecars lately is speedfactor in tga rebuilds them to custom specs and sets them up like a bilstein. Just xyz body and shaft with custom valve. Not cheap xyz you get off tardme.
I would love too, but with an 8 week old and only 1 income at the moment it's a bit of a juggling act.
There is always the option of custom springs. The shocks that are currently in there are in great condition, and I can get custom springs to any specs I want for a little over $400, which will allow me to spend more money in other places. :?
FST4RD
Postby touge_ae101 » Fri Nov 09, 2012 6:32 am
Once you increase your springrate the shocks will do bugger all. best option is to do it properly imo. good quality coilovers will make a car.
touge_ae101
Postby Bazda » Fri Nov 09, 2012 9:18 am
Can def set up a custom set for you.
We weld them to your oem struts properly so it passes a certification.
Our pices are very similar to D 2 & XYZ. Maybe a tiny bit more but your going to get a good quality setup.
D2's - The new range might be better than their old but their shocks are not valved correctly from what i've seen.
XYZ race series seem to be good but you would be paying good money for them. More than entry level Fortune Autos which do the same job as they are valved like a Bilstein with digressive valving.
fortune-auto.co.nz
At the end of the day it depends on if you want a good quality ride or if you dont mind to sacrifice ride quality for cost.
Postby Bazda » Fri Nov 09, 2012 9:19 am
Also why is it when I write "D 2" without a space it says cheap crappy??
Postby xsspeed » Fri Nov 09, 2012 9:39 am
lol someone has set up a word filter, haha
Postby FST4RD » Fri Nov 09, 2012 9:53 am
Bazda wrote:Can def set up a custom set for you.
cheap crappy's - The new range might be better than their old but their shocks are not valved correctly from what i've seen.
fortune-auto.co.nz
I'll be in touch this weekend.
If they work out and perfect for track work I know a few people in nz and aus that would be keen!
FST4RD
Postby d1 mule » Fri Nov 09, 2012 3:29 pm
another bazda add, i got them for my ae70 and the quality was freakin awesome. havnt driven on them but they look amazing lol
d1 mule
Postby Shrike » Fri Nov 09, 2012 3:57 pm
Im the same for Bazdas stuff got my ones wound fully up and its still sitting low and the car is stiff :p go sport valving
Shrike
Postby BattleSnayke » Sun Nov 11, 2012 11:10 pm
With the welding required for fortune auto, is it definitely certifiable? I heard that certing any suspension that requires welding is near impossible at the moment? Possibly looking for some for my AE70
98' GT-T Caldina
79' AE70 Corolla
BattleSnayke
Postby Bazda » Mon Nov 12, 2012 7:18 am
Welding to struts is fine as long as you do it right, take pics, and weld to mild steel not the cast parts.
Certified might want a crack test done which is shown on the pics above (white stuff on the bottoms).
Welding steering arms is an issue.
Postby wde_bdy » Mon Nov 12, 2012 12:33 pm
BattleSnayke wrote:With the welding required for fortune auto, is it definitely certifiable? I heard that certing any suspension that requires welding is near impossible at the moment? Possibly looking for some for my AE70
Can't weld to anything cast is the issue, note on mine the internally threaded section is welded to the strut tube only (with a sleeve for the smaller KP struts, AE70 probably won't need that). Those ones pictured have been xrayed and confirmed as ok with my certifier about 3 weeks ago.
Callum
wde_bdy
Postby d1 mule » Mon Nov 12, 2012 4:20 pm
It is you lucky day, I have photos if exactly what needs to be done (ae86 struts in a ae70)
Cut the existing strut tube off so there is still a small amount of steel to weld to.
You then get a piece of steel spun up (cost my $40) to slip inside the bottom of the strut and also the new Fortune adjuster sleeve.
Put it all together like a boss.
d1 mule
Users browsing this forum: Google [Bot] and 32 guests
