Shrike wrote:I use a press when I remove my pins just something Ive always done
Adoom wrote:I don't want to put a pot of oil on the gas stove....
Bazda wrote:I slightly heat the piston on the underside where the meat is around the gudgen. You only need to heat them a little and the pins come straight out.
BZG|Bling wrote:Adoom wrote:I don't want to put a pot of oil on the gas stove....
Why not? 60-70 degrees is piss all temp. My deep fryer goes to 190.
Adoom wrote:Gas stove... flames... a bunch of oil... seems like a bad combination.
Shrike wrote:if your in tawa this weekend your welcome to use my press I have had no damage when using it on any of my pistons except the one I forgot to remove the circlip on
mjrstar wrote:chuck them in the oven at 120 on fan bake for 20-30 mins, this should give you the desired amount of heating...
no messy pots of oil etc..
rollaholic wrote:mjrstar wrote:chuck them in the oven at 120 on fan bake for 20-30 mins, this should give you the desired amount of heating...
this.
just dont let the missus / mum find out
Users browsing this forum: No registered users and 37 guests
